Sc400 audio question
Old Nov 7, 2004 | 04:43 PM
maxthrottl's Avatar
maxthrottl
Default Sc400 audio question
Hi, I want to install 2 12" subs in my sc400. It has the nakamichi 12-disc 7 speaker sound system and the phone if that makes a difference. I was wondering what the easiest way to install the subs would be. Im assuming i need a new amp to power the subs. Is there a way to run the exsisting wires going to the stocksub through an amp and then to the Subs? Thanks
Old Nov 7, 2004 | 09:02 PM
PERRYinLA's Avatar
PERRYinLA
Yes, you'll need a new amp if you wish to run 2 subs. You can either:
1) take the wires going into the stock woofer and run them through an LOC ("Line Output Converter") which lowers their output and allows you to send their signals as regular inputs into an aftermarket amp, or
2) search CL for "Nak Hack" and follow the wiring diagrams to allow you to tap into the stock input signal wires and feed those directly into your add-on amp
Lots of SC owners have done what you are about to try, and have posted their experiences on CL's audio section. Search and you'll find lots to read up on.
JimSC300
Apr 20, 2012 05:50 AM
AZ IS350
Feb 8, 2007 02:05 PM
MrXerox
Jul 23, 2003 09:35 PM
spinteews
RX - 1st Gen (1999-2003)
Apr 30, 2002 02:33 PM
