Key programming difficulties - HELP
I have the master key. Actually the ***original*** master key's plastic cracked and dealer replaced it under warranty. But I guess it is still considered a master.
The other set of keys had been lost a long time ago.
So I bought a new transponder key blank from e-bay and had it cut, I also bought a valet key from Lexus-Parts.com.
I had no problems programming the remote keyless entry.
And the transponder programming steps don't look very difficult, but I can't make it work (neither the new transponder key nor the valet).
These are the steps that I followed from https://www.clublexus.com/forums/sho...highlight=key:
Lexus 1999-2003 RX 300 Key Programming - For NEW CUT KEYS
Process works with all keys - remotes, valet, non-remotes
1. Enter the car with a working pre-programmed key and close all doors. Simultaneously depress and release both the brake and the accelerator pedals.
2. Within 5 seconds, insert the working pre-programmed key into the ignition. DO NOT TURN THE KEY.
3. Within 15 seconds of inserting the ignition key, depress and release the accelerator pedal 5 times.
4. Within 20 seconds, depress and release the brake pedal 6 times.
5 Within 10 seconds, remove the working pre-programed key from the ignition.
6. Within 10 seconds, insert the pre-programmed key back into the ignition.
7. Depress and release the accelerator pedal one time. The security light should now begin flashing to indicate that the computer is reading the new key and programming the system.
8. Leave the new key in the ignition for at least 60 seconds. When the security light stops flashing, the programming process should be complete.
9. Test the new key. Place the key into the ignition and verify that the SUV will start.
10. If this is a new remote master key, test the remote functions on the new key.
I have no problems with steps 1-7. But then I keep the new key in the ignition for a looooong time and the security light never stops flashing.
Oh, by the way, shouldn't step #6 say "insert the new key into the ignition" instead of "insert the pre-programmed key back into the ignition"?
Is the preprogrammed key the new key?
The instructions should say "new" instead of "pre-programmed" in step #6
Where did you get your ebay blank cut? My dealer said they could not, and none of the big local stores (sears etc) could do it either
He also sells blanks on eBay and if people request he cuts them for an additional fee right then.
His name is Wayne Officer (or Offeceer). His e-mail address is wolftng@hotmail.com
P.S. some local locksmith wanted to charge me $70 to cut a key and got all defensive when I made a comment that that was a bit too steep, started telling me how his laser precision cutting equipment cost him thousands of dollars.
