mounting depth, rear speakers fr sc
what is the actual mounting dept for rear speakers on sc300/400?
im planning to install 6.5" 2-way speakers. do i need to modify anything?
tks for any help...
tks for any help...
There's nothing in the way- I installed a 6.5" 3-way Infinity Kappa in that position with no problems. Once you pop off the flexible rear trunk panel you'll see what I mean. The woofer, as you may know, is a whole 'nother issue though, due to the gas tank.
You may wish to disable the tweets to preserve the imaging, although I did not bother.
6.5" Kappas with no modifications to the stock speaker bracket at all? I installed kappa 4"s back there and they did look much wider than the fronts. Did you have to enlarge the hole to let the bigger magnet on the 6.5"s through?
I said "no problems", not "no modifications".
I did have to drill one or two new holes for the shifted position of the mounting screws. That was a tad tricky, since I had to manuver the drill into a tight area and not scratch the window defroster grid. I also had to fabricate a gasket ring out of some foam. These kind of things should be expected when upgrading speakers.
I measured that hole to be 4.5", so if your Kappas are smaller than that, you're good to go. Mine are, but they are from the 90's- the current generation may be larger.
Gotcha
In your opinion, do the 6.5s make a significant difference back there? I have the 4s and honestly I don't think they do much for the sound stage, some rear fill (which is to be expected I guess). You have 3-ways though, so I was wondering if you could hear a distinct difference
Sorry about the thread hijack...kinda
I only put in one 6.5 Kappa because the original stock 4" speaker failed. The other speakers did such a good job of covering up for their failed partner (I have the Nakamichi option) that I didn't even notice it for weeks until I fiddled with the balance controls !
So I'm unable to quantify the difference except to say I think the stock Nak sounds great, and still does with one driver upgraded to a 6.5 Kappa.
mikee72
08-08-04 09:57 PM
Big Pookie
07-13-04 10:03 PM
icgraven
04-10-04 02:08 PM
