Originally posted by aeropartz The PLUG goes nowhere...
Do you have a wire attached to the key lock cylinder in the door? this wire should run from the key lock cylinder down near the bottom of the door( so it clears the window when it rolls down).
It then comes out and the male/female plugs meet at the bottom/left of the big opening in the door.
I don't remember which side is male and which is female. The other wire this connects to comes out of the wire bundle.
If your door locks/unlocks fine(ignoring the loud noise of the alarm for the moment) from both the key hole and the power door lock button inside then I think your solenoid should be fine.
Your alarm will not work right without the above wire I talked about connected. It senses when the key is put in and disarms the alarm.
Maybe a previous owner messed up and broke/tore out this wire
