Parking Brake Detection Switch
Subscribe
Jul 19, 2004 | 11:47 AM
Hi All yesterday me and a friend intstalled a Kenwwood Indash DVD Tv on my 1999 Gs 300 everything went fine we had to rewire the speakers but the only thing we did not connect was a green wire that said Park Switch after we finished we turn on the monitor and we put on a DVD on then we didnot see no picture just sound after reading the Trouble shooting it says that the Park Switch has to be connected or there will be no Picture do you guys know were my Parking brake detection switch would be at? Please let me know Thank you.
Reply 0
Jul 20, 2004 | 06:01 AM
Im guessing that you need to tap in around the parking brake, so somewhere in the driver footwell. The reason it wont play is that Kenwood doesnt want you watching movies unless the parking brake is set. If it were me I would try to just ground the wire somewhere and see if that works. That way you could watch it while driving.
You should probably know that it is illegal in a lot of states to have a TV playing while in motion within the drivers eye-sight. Most people never have a problem with cops, the only people I know that have been hassled had monitors installed in their steering wheels.
Reply 0
Jul 20, 2004 | 09:40 AM
Parking Brake Switch
Im not sure on a Kenwood but sometimes you can get by by tapping ito the parking prake light wire so that you get power when the parking brake is applied, Unless they are like alpine where you actually need a small module to execute the barke - parking brake combination. To test if all you need is to tap into the parking brake light wire for a 12v source, just try touching the Parking Brake wire to the Constant power (yellow wire usually) once the unit is powered on! If that doesnt work then the must have some funky saftey switch like Alpine does! METAL
Reply 0
Jul 20, 2004 | 09:30 PM
Start by grounding the wire. that should work. You don't want to put +12VDC through this wire if all it needs it to be grounded. My 2 cents
Reply 0
Jul 21, 2004 | 09:05 PM
Thank you guys the one that worked was I grounded the wire and it worked.
Reply 0
Subscribe
