Running 1/0 gauge in SC300
Old Dec 25, 2003 | 10:37 AM
JSnake916's Avatar
JSnake916
Default Running 1/0 gauge in SC300
I am preparing to install an Xtant X1001 in my SC300. It requires 1/0 gauge wiring. Right now I have 4 gauge running from the batt. to a dist. block then 4 gauge to my two amps. The Xtant will be replacing my sub mono amp. I know that the 1/0 gauge is too big to run on the same route as the 4 gauge. Can anyone, who currently has 1/0 gauge running in their car, give me some tips/pointers/hints as to how/where to run this wire? Thanks in advance.
Old Dec 25, 2003 | 06:50 PM
FireCode's Avatar
FireCode
where did you run your power wire to get it through the firewall? I am trying to find a good spot for 4 gauge. thanks !
Nathan J St. Edwards University
Old Dec 25, 2003 | 07:18 PM
JSnake916's Avatar
JSnake916
There is a rubber grommet seal type thing that is deep under the dash on the driver's side. If you take out the wheel well lining, you can see it. You just have to feel around under dash to find it. Using this as the pass through is pretty easy and very clean. Remember to use some shrink wrap or similar to make sure the grommet is sealed when you're done.
On a side note to everyone, is it safe to say that running the 0/1 guage down the driver's side frame rail is about my only option?
Old Dec 26, 2003 | 03:21 PM
JSnake916's Avatar
JSnake916
Problem solved. After consulting some professionals, we came to the conclusion that my 4 gauge would be fine for my particular set-up.
SC300Gw
Aug 30, 2021 12:23 PM
Cioffdaddy
Jan 24, 2009 09:34 PM
redsharkIS
Dec 19, 2007 05:13 PM
jefthim
Jun 21, 2007 08:33 PM
golfkid777
37
Apr 20, 2007 11:23 AM
