Sound Problems
Old Jul 25, 2025 | 01:04 PM
Rcfloat's Avatar
Rcfloat
2nd gear
Default Sound Problems
Hello. im new to the forum, and came here searching for help. I recently got My 2016 RC350 With Non Mark Levinson Audio systems. I Got an OEM amplifier for it since the last one got wet. when i plugged it in still no audio. i ran the diagnostic On system check mode and there was no amp coming out on the list, It did say 0:EMV-M at Most. from the bit of research ive done its communication error?
System Check Diagnostic
The Amp option is missing. I come here looking for help any imput/ insight would be appreciated. Just wanted to ask on here before i strat stripping pannels and checking speakers and wiring
Old Jul 29, 2025 | 06:17 PM
Mc44's Avatar
Mc44
Since the amp isn’t showing up in diagnostics, it’s likely a communication issue either a bad amp, wiring problem, or incorrect unit. Double-check that the replacement amp matches your exact model non-Mark Levinson. If it’s the right one, inspect the wiring harness for damage or corrosion. A bad ground or CAN bus issue could also cause this. Test with a known-good amp if possible.
Old Jul 30, 2025 | 10:32 AM
Rcfloat's Avatar
Rcfloat
2nd gear
I Just ordered a new radio bc mine is acting up making clicking sounds while trying to eject the disk. scratching it in the process. so hopefully its the radio giving me issues.
Chapelli02
Feb 1, 2021 07:28 PM
DJKnetic
Apr 3, 2020 03:08 PM
Bluescreen
Aug 3, 2016 02:56 PM
c21girl
Oct 20, 2012 08:48 PM
duclex
Jan 25, 2005 09:03 AM
