Mark Levinson hacking
Car: '08 IS350 ML w/Nav.
My lofty goal is to keep the head unit stock, but allow switching between the DVD-A and another digital input source so that I can play hi-res FLAC, DSD, and *especially* 5.1 DTS material.
I love the idea of a modern double-DIN installed via the Beat-Sonic SLX-140L. But none of the current double-DIN head units appear to support pure-digital output, let alone 5.1 DTS.
That 5.1 is what makes the ML system really shine, imo. Don't get me started on burning my 5.1 material to DVD-A. What a PITA.
Thanks for reading!
TL;dr -- For an ML system, there's no straightforward way to input a digital stream other than what comes out of the DVD changer.
Your high-res FLAC, DSD, and DTS files/cd's -- yes, burn 'em to DVD-A. That's the only way to get MAX goodness out of the ML system until someone figures out how to feed a digital signal to the ML amp.
So, this is probably mentioned elsewhere, but the best quality you are going to get out of the ML system in a 2nd gen IS ... is (no pun intended) 24 bit, 96 KHz 2-channel, or 24 bit 48 KHz 5.1 channel, provided you do the needful:
IF NECESSARY, get ffmpeg. It's available in Windows via Chocolatey, Mac via Macports or Homebrew, and in Linux, almost naturally.
Then if necessary, resample your hi-res FLAC/WAV to 24/96 with ffmpeg syntax such as:
$ ffmpeg -i input.wav|flac -ar 96000 -sample_fmt s32 -c:a pcm_s24le output.wav
or for 5.1 channel DTS files:
First decode DTS to WAV with dcadec:
$ dcadec -o wav6 input.dts > output.wav
$ git clone https://code.videolan.org/videolan/libdca
Then, resample your 5.1 WAV files to 48 KHz to make sure they're compatible with the car:
$ ffmpeg -i output.wav -ar 48000 -c:a pcm_s24le output2.wav
and then burn those (or your 24/96 2-channel WAVs) to a single-sided DVD-A using a proggie specificallly made for that, such as discWelder Chrome. Burning DVD-A's is not trivial, but I've had much success with the aforementioned proggie.
Feel free to ping for advice if you have any hiccups.
