No USB 5 volt in center console 2018 RX450
Old Aug 23, 2024 | 04:40 PM
surfgregg's Avatar
surfgregg
1st Gear
Question No USB 5 volt in center console 2018 RX450
Coke was spilled tin the center console and now the USB power supply does not work on either of the USB ports. I have checked all of the fuse in the fuse panels under the hood and the riverside near the kick panel. They all have battery voltage when the ignition is on that I verified with a voltmeter. Is there a relay that is not getting switched to give the 5 volts. I have checked the ground side of the USB port to a battery voltage and it reads battery voltage so it seems the ground side is OK. I have read other inquiries about this problem have not seen any answers. Hope I just over looked something. Any suggestions?
DavidinCT
Dec 29, 2025 07:47 AM
socaligs
RX - 4th Gen (2016-2022)
17
Aug 12, 2024 01:33 PM
SpacBogdan
Nov 12, 2023 10:12 PM
r0cketpant
RX - 3rd Gen (2010-2015)
Dec 12, 2021 07:23 AM
Renrutjw
Feb 3, 2018 03:01 PM
