Why so few with Michelin's ?
Old Feb 25, 2023 | 12:32 PM
  #31
NiceCars's Avatar
NiceCars
Originally Posted by Badhobz
I thought the 4s meant 4 seasons. Their naming scheme is dumb
why call a summer tire 4s which sounds infinitely less sporting than super sport.
I think it might be the 4th version of the original SS
Old Feb 25, 2023 | 12:33 PM
  #32
NiceCars's Avatar
NiceCars
I’m hoping mine comes with the Michelins…maybe since it was part of the new $1000 price increase they’ll put on Pilots 🙂
Old Feb 25, 2023 | 03:18 PM
  #33
fodalo's Avatar
fodalo
Mich Pilot AS 4's great tire here in the N,E. wet dry light snow good performance all season tire. Much better than my original RF's, no brainer.
Old Feb 25, 2023 | 08:01 PM
  #34
Originally Posted by tmillLC500
'got us over 50k on our 2019 'stones; replaced em with (all we could get at the time) Pirelli RFT P Zero 's - and these feel like ballet slippers by comparison
replacing any performance car tires with 50k on them with any new tires will be a joyous revelation.
unless you don't want to be stuck somewhere with a flat tire.
Old Feb 26, 2023 | 11:05 AM
  #35
fodalo's Avatar
fodalo
Carry a portable battery operated Tire inflator. $68.00 great unit gauges and all.
Old Feb 26, 2023 | 07:03 PM
  #36
does you no good if it's a puncture.
Old Feb 27, 2023 | 11:48 AM
  #37
fodalo's Avatar
fodalo
It all depends Bit. You have times where thereis slow leak over night. In the case of a blow out neither have a chance.
Old Feb 27, 2023 | 12:26 PM
  #38
NiceCars's Avatar
NiceCars
The extended mobility kit that came with my M850’s HP tire and cooling pkg has an 12v electric pump and a can of goo to temp seal a leak if needed. I’d imagine if a large blow out occurred it wouldn’t be sealable at all and I’m not even sure a RF would be too much help. The bottom line is the extra comfort and better handling of non-RF’s is a trade off for the extra piece of mind one gets from the RF’s. Some have purchased a jack and doughnut spare which is the best choice.
Old Feb 27, 2023 | 01:33 PM
  #39
good points guys... maybe i'll try non rf's when it's time and have a can of the leak goo in the trunk (with my inflator).
Old Feb 28, 2023 | 04:24 AM
  #40
BruceinFla's Avatar
BruceinFla
Tires do not usually Blow Out from The Puncture. They blow out from heat build up from Driving on the low pressured tire After the puncture. The LC TPMS should give you notice of a low tire in Plenty of time to restore proper pressure with a small pump. I had a puncture for 2 days before it was repaired. The tire never went below 28-30 lbs pressure. Sometimes you can park with the puncture at the Very Bottom of the tire and it won't leak at all as long as it's parked. Bruce in Fl
Old Feb 28, 2023 | 06:56 AM
  #41
MLMLC52K18's Avatar
MLMLC52K18
In all the years that I’ve been driving, I have never suffered a complete loss of air while on the road. Sure, all of us have probably picked up a nail which causes the tire to loose pressure slowly. Left unattended, your tire goes flat. Just like B… said; TPMS will alert immediately of any deviation in pressure levels of your tires….. I only drive my LC locally. I carry an air pump and a tire patch kit in all my vehicles for emergencies…. For most of my tire emergencies, that is more than enuf....
Old Mar 6, 2023 | 11:16 AM
  #42
928GTS's Avatar
928GTS
Combination of 12V air pump and one of these will work as long as hole is on thread area. If its on sidewall its usually not safe to fix it on the road or at all anyway. I would use patch goo only as last resort. It makes a mess inside tire and wheel. But its probably only option for most people on side of the road.
Eng11
NX - 2nd Gen (2022-current)
Jan 22, 2022 06:56 PM
LoganFive
May 18, 2018 08:38 AM
LexusNN
CT 200h Model (2011-2017)
Mar 12, 2012 03:21 AM
brociouz
Mar 4, 2010 04:37 PM
Stefwilli
Sep 23, 2009 08:39 PM
