Pre Collision System Malfunction
Old Jun 28, 2022 | 09:19 AM
Marwan74's Avatar
Marwan74
Default Pre Collision System Malfunction
I just had my tires changed and the car has been lifted for alignment. Since then the PCS is flashing along with the warning sign is on. nothing related to the radar is working. Has anyone experienced this before?
my LC500 is 2018
Old Jun 28, 2022 | 07:55 PM
was this done by the dealer? either way, something got knocked or broken.
Old Jun 28, 2022 | 09:15 PM
Marwan74's Avatar
Marwan74
Nope, not by the dealer. I just found these general guidlines on when to turn off the PCS and I highlighted below what could be the cause of the malfunctioning of the system. let's hope it is a re-setting issue.
a) Make sure to turn the pre-collision system off in the following situations, as it may operate unexpectedly or may not operate when necessary.
  • When the vehicle is being towed
  • When the vehicle is towing another vehicle
  • When transporting the vehicle via truck, boat, train or similar means of transportation
  • When the vehicle is raised on a lift with the engine running and the tires are allowed to rotate freely
  • When inspecting the vehicle using a drum tester such as a chassis dynamometer or speedometer tester, or when using an on vehicle wheel balancer
  • When a strong impact is applied to the front bumper or front grille, due to an accident or other reasons
  • If the vehicle cannot be driven in a stable manner, such as when the vehicle has been in an accident or is malfunctioning
  • When the vehicle is driven in a sporty manner or off-road
  • When the tires are not properly inflated
  • When the tires are very worn
  • When tires of a size other than specified are installed
  • When tire chains are installed
  • When a compact spare tire or an emergency tire puncture repair kit is used
  • If equipment (snow plow, etc.) that may obstruct the millimeter wave radar sensor assembly or forward recongnition camera is temporarily installed to the vehicle
Old Jun 29, 2022 | 06:06 AM
azmojo's Avatar
azmojo
How inspiring! I haven't tried towing anything with my LC yet. If only it snowed in Phoenix I would have to try a snow plow attachment.
Old Jun 29, 2022 | 08:36 AM
Marwan, good guidelines, but did they not have any additional guidelines to FIX it? maybe disconnect the battery for a while?
Old Jun 29, 2022 | 10:53 AM
Marwan74's Avatar
Marwan74
Talking
Phoenix? Snow?
Old Jun 29, 2022 | 10:54 AM
Marwan74's Avatar
Marwan74
I did try that but no luck
Old Jun 29, 2022 | 08:03 PM
azmojo's Avatar
azmojo
It sounds like the kind of thank that can be fixed with a power cycle. Can you disconnect the battery for a good long time and then reconnect it?
Old Jun 29, 2022 | 10:42 PM
Marwan74's Avatar
Marwan74
I disconnected it for almost 90 mins. shall I try more?
Old Jun 30, 2022 | 07:37 AM
azmojo's Avatar
azmojo
In my experience that should be enough.
Old Jul 7, 2022 | 06:18 AM
Marwan74's Avatar
Marwan74
Problem Solved.
I took the car to the dealer. The lane keeping assist was programmed and calibrated. Everything is back to normal.
Old Jul 7, 2022 | 04:53 PM
NiceCars's Avatar
NiceCars
Problem Solved.
Nothing like a quick and simple fix
Old Jul 14, 2022 | 01:38 AM
Marwan74's Avatar
Marwan74
Unhappy
and expensive fix too
costed $400
Old Jul 16, 2022 | 09:02 AM
where are you Marwan and i guess not under warranty?
Old Jul 18, 2022 | 03:43 PM
RysLC500's Avatar
RysLC500
costed $400
This is why I always buy new and try to keep my miles and years under warranty in line with each other. Don't like to deal with unknown costly repairs.
