Tracked the LC (but not really)
Old Sep 8, 2021 | 06:48 PM
LXSDO's Avatar
LXSDO
Originally Posted by DRGibbons
What do you mean by 'usual overheating'???
Excessive temperature for either the oil or the coolant is an issue (possibly catastrophic) for the engine. You should investigate, or, as it sounds, you should have a qualified person investigate the root cause if excessive temperatures of either fluid if observed. They can have drastically different reasons.
Dr G,
I meant most cars only report a coolant temp and traditionally I've gauged that as a concern for overheating. When you tracked the car, you observed higher oil temps. Not sure if you noted any changes to coolant temps. After several hard pulls it should be expected for the oil temp to rise but if the coolant is normal range then I should be ok? The only reason I ask because my RCF reads out both. But the oil temp was always the last to heat and never went over middle. Thanks.
Old Sep 8, 2021 | 07:05 PM
Exhilr8n's Avatar
Exhilr8n
Originally Posted by LXSDO
Dr G,
Interested to hear your comparison of the handling, driveability of the LC vs your previous Lexus.
Old Sep 8, 2021 | 08:09 PM
bitkahuna - that statement is a bit scary. You might go back to that suggestion I made a long time ago and at least do a quick review of the manual.
Thanks for your concern and advice. Any particular part of the 450 pages i should do a quick review of?
Old Sep 8, 2021 | 08:32 PM
DRGibbons's Avatar
DRGibbons
Maybe the Gauges & Instrument cluster readouts for a start . . . . . Section 2 - pages 68 through 94 . . . . it's an easy read and very informative. You can skip over the LC500h sections.
Old Sep 8, 2021 | 08:57 PM
it's pages 75-104 on mine so i guess the manual has grown. I skimmed through it
sensai
RC F (2015-present)
23
Aug 10, 2021 10:07 AM
KayGee
Mar 30, 2021 09:34 AM
thatnewguy
IS F (2008-2014)
Oct 13, 2015 09:13 PM
I8ABMR
IS F (2008-2014)
22
Jun 25, 2015 10:50 PM
