Backup camera issue
Old Mar 24, 2019 | 04:53 AM
anchaf3's Avatar
anchaf3
Default Backup camera issue
Out of nowhere, the yellow lines (the ones that will move when turning my steering wheel while backing up) have disappeared. The static blue lines are still there. Has anybody has this issue? Is there a setting that I can change to bring this back?
Old Mar 24, 2019 | 12:42 PM
Ahhadanny's Avatar
Ahhadanny
easy fix: put the car into reverse mode. While the backup camera image is on, push down the mouse pad to choose whether you want trajectory lines (both blue and yellow lines as you mentioned - you can have both, none or just one).
Old Mar 24, 2019 | 01:30 PM
anchaf3's Avatar
anchaf3
I’ve actually done that. I’ve gone through every option in regards to tapping the trackpad. I’ve not been an able to get the yellow dynamic lines back.
Old Mar 26, 2019 | 05:25 PM
anchaf3's Avatar
anchaf3
these are my only options when pressing on the track pad
Old Mar 29, 2019 | 01:28 PM
offroad200's Avatar
offroad200
Put the car in reverse, turn the wheel all the way to the left and hold for 2-3 seconds, turn the wheel all the way to the right and hold for 2-3 seconds.Return the wheel to center. Your lines should come back.
Old Mar 31, 2019 | 04:52 AM
anchaf3's Avatar
anchaf3
Still not coming back. I am not sure what the deal is. I guess I will just take it to the dealer and let them look at it.
Old Mar 31, 2019 | 12:18 PM
hoonose's Avatar
hoonose
One possible suggestion that commonly worked for Corvettes is to disconnect the battery for 10 minutes then connect and let the onboard computers reboot. Sometimes that cures gremlins like this.
Old Mar 31, 2019 | 02:48 PM
anchaf3's Avatar
anchaf3
already tried that one as well.
Old Apr 1, 2019 | 09:47 AM
DRGibbons's Avatar
DRGibbons
Have you tried to do a software update?
Old Apr 1, 2019 | 11:05 AM
mcomer's Avatar
mcomer
Your sequence of photos show the lower left icon pattern perfectly, each icon shown displays the next screen
that should come up when pressed. The initialization function of turning lock to lock is usually only needed once
when the car is new. Another approach you might consider is marginally more severe than the 10 minute battery
disconnect, go into the menu and "Delete Personal Data". Intended for use when you sell/trade the car it will remove
absolutely everything, phone pairing/call logs/destinations/Lexus App Suite...everything. Then try the guide line
initialization with the side to side steering. Be sure to pause a couple of seconds at each extreme steering angle.
You will have to repair the phone and re-enter important and frequent destinations. Service reminders and Dealer
information will also be wiped out.
Old Apr 26, 2019 | 02:40 PM
justin1203's Avatar
justin1203
Hello,
I have a 16 RX350 and while searching for threads on my issue, this one came up.
In picture number two and three, what is that short blue line in the middle? I notice mine has it on it now as well, and unless I've completely blanked on the last 3 years I've owned this vehicle, I do not recall ever seeing it before.
Thank you!
Old Mar 28, 2020 | 02:44 PM
Rikstah's Avatar
Rikstah
Did you ever fix this issue? I know it’s been a year ago but I’m having the same issue with my 2020 ES350 after my battery died.
Old Mar 28, 2020 | 07:26 PM
anchaf3's Avatar
anchaf3
After a few trips to the dealership it was finally resolved. I have not had a problem since.
Old May 11, 2020 | 03:09 PM
Steve916's Avatar
Steve916
I have the same issue with my 2020 ES350. Did you do something to fix the issue or did you have to take it to the dealer? Thanks.
Old May 11, 2020 | 03:11 PM
anchaf3's Avatar
anchaf3
I took it to the dealer and they were able to figure it out. I wish I could be of more help!
