Scheduled service
Old Jan 28, 2019 | 03:19 PM
OregonLC50's Avatar
OregonLC50
Default Scheduled service
My '18 LC has a few more than 15K miles on it and I'm going to have a service done soon. I usually buy Mobile 1 synthetic at Costco and have dealer install it with new wiper blades and oil filter, skipping most everything else on the list. However; the dealer said that included in this service is a computer update. I don't expect to now have Apple Carplay, but have complained previously that in auto D mode the transmission doesn't up-shift to the highest gear soon enough and maintain it; I want the lowest engine rpm for marginally better fuel efficiency unless I choose to drive aggressively. (Coasting down hill is a good example; the car constantly overrides driver selection even in M mode) Anyone know what this update does as dealer was not sure?
Old Feb 9, 2019 | 06:49 AM
dagsmcd's Avatar
dagsmcd
Do not know about the update but a couple of questions as I am at the same mileage and am interested in the same rpm issue.
I thought the next oil change was at 20K (having done it at 10) and the 15K was just tire rotation and a general check up. I just had mine in at 15 for the brake squeal TSA (which has worked out great, by the way) and they did not mention a computer update or oil change at 15K.
On the rpm, I would also be interested in that fix - what drive mode are you using? I have a custom ECO/Comfort setting that seems to minimize that issue on the highway when coasting, but not completely. (Mine is a hybrid, so maybe that makes a difference). Thanks.
Old Feb 9, 2019 | 10:42 AM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^Tire rotation Front and rear tires and wheels are different.
Lou
Old Feb 9, 2019 | 10:46 AM
OregonLC50's Avatar
OregonLC50
Default Service
My LC is an ICE with performance package. Curious that you mentioned tire rotation; that's impossible on my car as the front tires are not the same size as the rears. I read that the '19 model has -- in addition to Apple carplay-- a few adjustments to the engine/transmission and perhaps a few other minor things beside a special order yellow paint. We've had some snow in my area so I might have a better idea of what specific engine/transmission mapping changes were made, if any, after the service when the snow melts.
Old Feb 9, 2019 | 12:20 PM
dagsmcd's Avatar
dagsmcd
Tire rotation is just what thy told me is scheduled at 15 when I brought it in for the brakes - I didn't even think about it as I had just put winters on mine but, obviously, the front and rear are different sizes. Maybe they were just going off of a generic Lexus service list -- neither I nor they thought about the inapplicability to the LC.
Too bad the car play is not backward compatible to the 18.
Old Feb 10, 2019 | 11:38 AM
web4488's Avatar
web4488
Too bad the car play is not backward compatible to the 18.[/QUOTE]
Has anyone checked into the viability (and cost) of exchanging the existing 2018 radio for the new 2019 radio?
jimmyzhu
Aug 14, 2009 09:06 AM
EGLIDE
Jan 14, 2008 12:38 PM
MikeP
Maintenance
Jul 16, 2005 08:50 AM
dzar
RX - 1st Gen (1999-2003)
Dec 19, 2003 04:17 PM
RXKen
Aug 21, 2001 06:44 AM
