Armrest removal?
Old Dec 7, 2025 | 01:54 PM
Lexusdriverpcb's Avatar
Lexusdriverpcb
Default Armrest removal?
Searching the form I had not been able to find any information on removing the center armrest top pad. I’ve been investigating and it seems like it’s being held but in a very unusual way. I’m thinking to remove the top pad that is on the double hinges. All the information I’ve seen via Internet is talking about removing the whole council, that’s ridiculous. If you lift the lid up and you look underneath, you do a little prying here and air. It’s definitely being able to separate in 2 pieces. I just don’t know how. There is no binding within sight of the top pad. It’s up underneath somewhere, but I just don’t know how to get to it. Thank you for your help
Old Dec 7, 2025 | 08:10 PM
Mc44's Avatar
Mc44
It's clipped in from underneath. You have to remove the whole console to access the clips. There's no way to separate the pad from the hinge assembly without taking the console out first. It's a pain, but that's how Ford designed it. A trim tool set helps for prying the console pieces up.
Old Dec 7, 2025 | 08:34 PM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^Ford
Lou
Old Dec 8, 2025 | 06:57 AM
tecman's Avatar
tecman
If I’m following that correctly, you’re trying to remove the center console pad cover assembly from the hinge.
It looks like you need to remove the four small caps to access the red screws, which will let you open the cover and give you access to the yellow screws for the hinge.
Steve022
UX Models (2019-present)
Mar 14, 2025 01:50 PM
Enforcer84
Mar 27, 2018 10:42 AM
KarliSue
GX - 1st Gen (2003-2009)
Aug 26, 2016 11:13 PM
Rotary13b
Jan 20, 2009 01:13 AM
YupImJOee
GS - 1st Gen (1993-1997)
Mar 1, 2008 07:55 PM
