MY26 bespoke coupe missing LSD?
Old Dec 4, 2025 | 05:30 PM
hughwotmait's Avatar
hughwotmait
10th Gear
Default MY26 bespoke coupe missing LSD?
Just got my vin and the spec sheet from the factory but noticed it did not have the LSD listed. This was not optional for the bespoke coupe as it came bundled together with the bespoke package.
Is this the same for anyone else?
I noticed the builder for the bespoke coupe no longer exists on the website either so i cant reproduce it but do have my old build saved.
Factory sent spec sheet:
original website builder output is attached as a PDF
File Type: pdf
Old Dec 4, 2025 | 06:45 PM
np20412's Avatar
np20412
Yes that's correct. It's included in the bespoke so it doesn't get it's own line item on the build. If it's bespoke it will have LSD.
Old Dec 4, 2025 | 07:22 PM
NickL's Avatar
NickL
Bespoke is based off of the sport package so the LSD is included.
Old Dec 4, 2025 | 07:28 PM
hughwotmait
10th Gear
Yes i thought that as well. But a bit concerned it doesn't show up in the factory produced spec sheet when it showed up in the builder under the Performance section. Waiting to hear back from the dealer tomorrow.
Old Dec 4, 2025 | 07:30 PM
NickL's Avatar
NickL
You can ask them to put the car on the lift and take a picture for you. Maybe it can be spotted(?)
Old Dec 5, 2025 | 09:11 AM
hughwotmait
10th Gear
Just spoke to my rep who reached out to Lexus. None of the 26 bespokes will come with an LSD
Old Dec 5, 2025 | 09:19 AM
RyanRA's Avatar
RyanRA
Then Lexus should update their website, too. The Bespoke convertible build does show the LSD. But there is no Bespoke coupe build option.
Old Dec 5, 2025 | 09:22 AM
hughwotmait
10th Gear
Wow! Maybe there is some misinformation/miscommunication inside Lexus Corporate.
Well regardless I am still purchasing the vehicle pending delivery. So I guess we will have a real answer sometime in February .
Old Dec 5, 2025 | 11:10 AM
Korbek's Avatar
Korbek
I have to believe as mentioned it just isnt a separate line item. It makes no sense that the 2026 bespokes wouldnt have the LSD when prior years did.
Old Dec 5, 2025 | 07:11 PM
Veight's Avatar
Veight
The bespoke build option on the coupe is $3,600. On my convertible with LSD it’s $5,500 for bespoke build option .
Old Dec 8, 2025 | 02:48 AM
sachmthom's Avatar
sachmthom
How do you spot the LSD? Won't this housing be same whether the car has LSD or Open Diff?
Old Dec 8, 2025 | 12:50 PM
flowrider's Avatar
flowrider
Veteran: Air Force
^^^^Yes - In appearance, they are the same.
However, this might work:
Lou
berserkr
Jun 24, 2022 04:12 PM
wcarr8888
Jun 6, 2022 09:31 PM
djpauldc1
Oct 29, 2010 12:28 PM
isam250
Oct 16, 2006 03:24 PM
gs300_r1
GS - 1st Gen (1993-1997)
Feb 20, 2005 07:16 PM
