Changing front tires only
Inside of my front tires got worn out prematurely due to either a toe or chamber issue so need to replace right now, but my rears still have ~30% left, is it ok to just change the front?
I have heard somewhere that handling might suffer a bit in wet weather if only front tires are new?
I believe the perceived wisdom is that one should fit new tires to the rear and so your existing rear tires should be relocated to the front, BUT they cannot because of the staggered sizes on the LC. The only option is to fit new to the front and judge the handling with a view to renewing the rears if anything untoward is experienced.
Yes very normal. There's negative camber to help with cornering (which is true of most performance cars) but it does lead to the inside tire getting worn more quickly when not cornering (aka the majority of street driving).
OK, I'll disagree here. Replace all four. Your rears will have far less traction than your new fronts and could put you in a dangerous situation. This is a $100K car, don't treat it like a ten year old Corolla
Replacing only two tires on that Corolla with a square setup, the new tires would go on the rear:
https://www.lesschwab.com/article/ti...m-on-back.html
https://www.wfirm.com/when-replacing...front-or-back/
https://www.goodyear.com/en_US/learn...two-tires.html
https://www.discounttire.com/learn/r...%20rear%20axle!
Nuff Said
Replacing only two tires on that Corolla with a square setup, the new tires would go on the rear:https://www.lesschwab.com/article/ti...m-on-back.html
Nuff Said
Why, and back up please?
I could understand that to be the Optimal solution but my rears will wear out way before my fronts. I don't drive my car at 8/10s. I'd really rather not replace $1100 of completely useable tires unnecessarily.
Bruce in Fl
Bruce in Fl
The need for same tires installed at the same time is more pertinent when driving an AWD car.
That said I only driven Michelins so I would never put any other brand on my car as the tires are the only thing touching the ground - arguably the most important component on a car then
My 18 SGM came with Stones. I'd prefer Michelins. With the rears being closer to my butt And ears, I suspect I may actually notice any improvement the Michelins may bring. I'd guesstimate I have at least 8mo-1 year left on the fronts.
Aesthetically, if someone wants to get the 18" close enough to see the different tires, have at it.
Bruce in Fl
Bruce in Fl
When replacing only 2 tires too many people mix tread styles. If you have summer rated tires you need to stick with that on all 4 corners. Same with all seasons. I know the tires sizes are going to be different, but the handling characteristics should remain the same.
Joegx
GX - 2nd Gen (2010-2023)
23
Jun 16, 2022 10:52 PM
DaveN
Nov 22, 2010 02:34 PM
FuMoFFuTT
Mar 4, 2010 02:22 PM
