Carbon fiber hood install help
Old Jun 11, 2025 | 05:02 AM
np20412's Avatar
np20412
Originally Posted by dodgediesel
Hmm I don't plan on buying one of these but I noticed this when I was checking out the website.
Gas Struts Warning Do not use stock shocks, dampers, struts, or springs. Carbon products are lighter in weight, so these mechanisms may prevent your hood and/or trunk from closing and may cause products to crack due to pressure.
Wonder what the weight difference is between the stock one and the Seibon. If it does crack they might ask if you used the OEM struts.
The seibon hood weighs 41lbs. Its about the same as the stock hood. It's a visual mod really, it's not made of dry carbon. It's CFRP wet carbon.
Old Jun 11, 2025 | 06:04 AM
tecman's Avatar
tecman
What are you going to do with the OEM Hood? We have basements for that sort of stuff here in Georgia
Old Jun 11, 2025 | 06:16 AM
np20412's Avatar
np20412
I'm going to figure out some way to mount it on the wall in my home office
Old Jun 12, 2025 | 08:32 AM
iamnaeem's Avatar
iamnaeem
Originally Posted by np20412
Haha perfect! Thank you much! Does the bumper need to come off to perform step 6?
No need to remove the bumper. You should have enough room to access without. Also, yes the carbon hood weighs pretty much the same as oem so you can reuse the same struts.
Old Jun 12, 2025 | 10:04 AM
np20412's Avatar
np20412
Thanks!!!!
Old Jun 12, 2025 | 10:59 AM
tecman's Avatar
tecman
Does that hood sit higher than OEM?
These guys are installing a supercharger and have been posting several short clips lately showing the progress. Not sure if the hood was already on the car or if they installed it specifically for this build.
Old Jun 12, 2025 | 12:09 PM
np20412's Avatar
np20412
Based in pics it appears to sit the same but there may be room inside if it doesn't have the same thickness/liner etc on the underside? I'll post some pics when mine is delivered
Old Nov 24, 2025 | 05:29 AM
tecman's Avatar
tecman
Video showing installation and latch modification.
Ultra3is
Feb 19, 2021 04:17 PM
bigwes
Jun 6, 2012 10:03 AM
DoHwan
Jan 27, 2008 11:33 PM
JDMJim
Nov 10, 2003 02:45 PM
