Transmission failure?
Well, AAMCO said the valve body was clogged
Does this mean replacing the solenoids could possible work?
Calling Lexus Corporate to complain since the car was regularly serviced at the dealer and see if they can help in anyway, not expecting them to, but worth a shot
Found a used ISF transmission from a 2012 with 22k miles that has been sitting at the salvage yard for three years, for a great price, so considering that
Not sure if you get this but my 08 with 154K feels weird when going from a stop. Feels like it's not in gear, revs a little bit, then catches first. Idk, I'm moving so I must be in gear, just feels like I'm not.
but, my reverse does that sometimes
if you believe it’s a transmission issue, id recommend replacing the trans filter and do a drain and fill
taking my L
i found two transmissions
one with 33k miles for $2300
and another that’s been sitting for three years with 22k miles for $1500
or could go through lexus dealer for $10k…
Keep in mind you'll need to flush the coolers at a minimum. Many would recommend replacing the air/oil cooler out of precaution. This is standard with engine oil coolers if there is an engine failure.
I’m going through with the new transmission via AAMCO.
They just ordered the transmission today and should be all finished by next Friday
It has under 30k miles with a 90 day warranty
He said they will flush the entire system
Going to upgrade the radiator, transmission cooler and engine oil cooler in the near future before I add performance mods
If you look at the mother of all ATF threads, the first recommendation is always to fix the level. It's really rare to have DTCs from low fluid though. Usually you get flare from 1st to 2nd and you'll get a no shift situation after a hard turn. Glad it was a simple fix!
That's crazy you described it like that because my 08 is doing all 3 of those you just mentioned, car has 175k on it. The shift flares were frequent at one point but became kind of few and far between, but sometimes it will hang in gear for a few seconds if I make hard left turn. I was thinking maybe needed fluid top up but the Lexus dealership here is kind of leery of fluid changes on F trans I was told
supra46
IS 500 (2022-2025)
145
Mar 2, 2023 08:41 PM
Waleedjatt
Jan 15, 2021 06:19 PM
oyeitsdean
Apr 17, 2017 07:33 PM
silvertn35
RX - 1st Gen (1999-2003)
17
Mar 6, 2010 04:37 PM
