Maximum Safe Piston Speed Redline
Unless someone speaks fluent Japanese and manages to get a Novel ISF engine autopsy, it's hard for any of us to say exactly what happened to that car.
Do any of you know the mods on the car? The tune? The support mods? Oil? Fuel? Use? Etc
I think it's safe to say that we should probably look at upgraded valvetrain soon if we want to shoot for the moon.
As for the Loi Tune, it's not possible to get just the TCU portion done when the entire tune needs to be done together.
Just get Tuned by Loi, no pun intended.
Bringing this up for those with 6800rpm+ limit removed did it help with keeping the car torque converter locked? i believe an issue some had was when switching gears the torque converter would not stay locked.
I have a tune from Loi with a 7300 rpm rev limit. It shifts at 7200 reliably in D (as we agreed) with the converter locked. If you raise the redline, your tuner will need to make adjustments to make the transmission hold in gear to redline.
Blackraven
May 9, 2015 12:55 PM
