Factory intake cover modification
Old Feb 16, 2022 | 03:52 PM
lowacura's Avatar
lowacura
10th Gear
Default Factory intake cover modification
Wondering if anyone has attempted to remove the cloth cover and surrounding on the top side of the air filter cover on their ISF? I have a k&n filter now but it seems like the top cover is restricting half of the air flow?
Old Feb 16, 2022 | 04:45 PM
Rickna's Avatar
Rickna
K & N intake requires you to remove the entire stock air box.
Old Feb 16, 2022 | 05:40 PM
flowrider's Avatar
flowrider
Veteran: Air Force
OP didn't say he had a K&N intake he said he has a K&N filter:
https://www.knfilters.com/air-filters/lexus/is-f
And Yes - folks have removed the filtering material from the top intake cover. I did it before I replaced it with a Takeda intake.
Old Feb 16, 2022 | 05:45 PM
lowacura's Avatar
lowacura
10th Gear
Forgot to mention it was a k&n drop in filter.
Is there a difference when you remove the white material? Noise difference? Slight noise difference?
Old Feb 16, 2022 | 05:53 PM
Rickna's Avatar
Rickna
You're right. And my medication seems to working...
Old Feb 17, 2022 | 05:48 AM
Jwconeil's Avatar
Jwconeil
I’m curious why you run an aftermarket intake? The oem one is very good.
Old Feb 17, 2022 | 05:59 AM
Rickna's Avatar
Rickna
I know the consensus is that a few ponies are lost with an aftermarket intake, but I like the sound.
Old Feb 17, 2022 | 06:14 AM
Joe Z's Avatar
Joe Z
Lightbulb
I am NOT a fan at all of the K&N and/or oiled drop in filter.. It requires additional maintenance and for many a CEL down the road when the oil particles attach themselves to the MAF sensor element.. which then also requires cleaning..
Also I would leave the Carbon Filter attached to the lid as is.. Over a decade ago members measured a HP loss when removed…
The teabag filter is a carbon filter to remove hydrocarbons when the engine is sitting. The most difficult emissions test to pass is the SHED test. The tester seals the car in what amounts to a shed and measures the hydrocarbons the car emits over a three day period. Exhaust emissions are a cakewalk compared to this test. The filter is critical to ensuring any hydrocarbons in the intake are absorbed instead of released to atmosphere.
Joe Z
wheezer1
NX - 1st Gen (2015-2021)
Jun 21, 2021 11:15 PM
Akiva253
RX - 4th Gen (2016-2022)
Mar 14, 2021 10:23 PM
lexuslover
CT 200h Model (2011-2017)
Aug 24, 2011 11:35 PM
