2011 Lexus ISF headlight issues
Thought I'd ask here since it's related. The MY changes sticky mentions the 2011 having LED headlights. My VIN check says the specs are BiXenon. Here the OP doesn't have BiXenons. Anyone able to shed a little light?
Were the LEDs only on some 2011s? Were the OP's BiXenons changed out to lows only at some point?
Low beam is HID. High beam and fog are xenon/halogen (xenon is a halogen gas). DRL in the early models is a reduced power to the high beams making them look a pathetic yellow color which was replaced with LEDs in 2011 and later models.
So the high beams are indeed led in MY11 and up? And I can use xenon for fogs?
And those are the only OEM LEDs in any IS F. LED headlights came much later for Lexus. RC F has them as an option, and GS F came with triple LEDs on all US models. I like the GS F headlights a lot. They work well.
So let me ask you this. I have a 2011 IS 350. Today my left beam went out and the DRL on that side is also flickering. Sometimes it works, sometimes it doesn’t. Is this a bi-product of the low beam bulb going out? Basically, if I replace the low beam, should I expect to see everything go back to normal or should I take this to Lexus right now?
Luxotic
Jul 31, 2012 05:51 AM
