Help needed about springs...
Hello.
I've searched answer for this, but couldn't find. Sorry, if its out there.
I just installed Bilstein B6 shocks, but now at highspeed the ride is wobbly, I don't like it.
Is there a way to stiff the ride remaining the OEM height? Finland roads are not the best (speedbumps everywhere) and with huge amount of snow, I need the OEM height.
If I understand correctly, the 2012 ISF has better springs, can I fit those with my 2008 model? If someone could give some advice how to improve ride quality remaining original ground clearance or with minimal lowering...
Thank you!
-Timo
Thank you!
-Timo
Can you explain wobbly better? The 2008 and 2012 springs are essentially the same rate. The big change was the shocks, but that meant new springs diameter and that means they don’t interchange.
That’s bad news to me. I think you’re the first to be disappointed by the B6 meaning, most say it’s better than stock.
Many report the swift springs a a good match for b6 but I’m skeptical they would be softer than OEM.
Thats the reason I went for B6, because everyone liked it. Slower speeds, yes its not so harsh, but in faster speeds its almost scary. I have the USRS from RR and swaybar in rear.
When I go over 60mph on a twisty road, it doesnt feel so stable. It felt more planted at higher speeds before Bilsteins, not as jumpy. I'm sorry, I'm not very good at explaining in English.
daryltrinh
Aug 7, 2010 10:09 PM
TopRamen
Suspension and Brakes
28
May 14, 2010 06:38 PM
ToyotaLexus
Nov 8, 2001 11:20 PM
