Low Coolant affects a/c compressor?
Old May 27, 2020 | 03:23 PM
DCoolBeans's Avatar
DCoolBeans
Default Low Coolant affects a/c compressor?
This has happened twice already. My car drops idle and compressor kicks off while ac is running then cycles back on in a few minutes. No cold air for that time its off
Ive noticed the coolant low and topped it off. Doing that will fix my ac problem.
My question is, are they related? Is this something else that needs fixing?
Ive heard about the vally plate leaks but I have not checked mine out yet if it is. I haven't looked into how to check it out. I just notice the reservoir low. I add coolant and check it the next day and its low again
Old May 28, 2020 | 09:13 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
What do you mean by the compressor kicks off? The compressor never shuts off, it just goes to a minimum setting. There is no clutch at all. Are you saying the HVAC control shows A/C off?
When was the last time you topped off the R-134a? That's the most likely root cause of A/C issues.
Old May 28, 2020 | 10:16 PM
DCoolBeans's Avatar
DCoolBeans
I guess what I’m saying is it will keep blowing but it will not cool. I hear the engine idle lower.
Then a few minutes later it idles up and begins cooling again
Old May 29, 2020 | 09:41 AM
Joker4096's Avatar
Joker4096
Low refrigerant maybe?
Old May 29, 2020 | 02:11 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
I'd bet on it. There's a high/low switch in the freon circuit that will put the compressor in a minimum state (since it doesn't have a clutch) and it won't kick back on until the pressure rises enough. Most likely situation is the refrigerant is right on the borderline of too low, and as soon as the swash plate gets set to a high enough setting, the low pressure detection kicks in and shuts the process down.
Old Jun 6, 2020 | 03:59 AM
jdmek998's Avatar
jdmek998
Sounds like you are low refrigerant. Coolant and cold ac are not really relater. Now it will affect your heating.
colfax
Feb 24, 2020 06:39 PM
biacs
Aug 24, 2018 07:02 AM
wcl77
Aug 10, 2014 05:52 PM
RX330inFL
Jun 28, 2011 07:54 AM
EllenRX
RX - 1st Gen (1999-2003)
Aug 23, 2006 07:33 AM
