Tom's front lip and diffuser hardware/gaskets/etc
Old Dec 10, 2019 | 10:50 AM
DAng87's Avatar
DAng87
Default Tom's front lip and diffuser hardware/gaskets/etc
Hey everyone,
I just picked up a used toms rear diffuser and front lip but neither came with any of the hardware and gaskets.
I've used the search function but never found the answer i was looking for.
Front- i believe is some bolts and washers and maybe a bracket or two
rear- 3m tape is easy to find, im looking for the edge trim...has anyone used the diffuser without that edge trim? I had the diffuser in the past that i bought from one of the forum vendors but it got destroyed after being rear-ended, it came with everything i needed but since this one is used it didnt come with the edge installed.
Thanks!
Old Dec 10, 2019 | 10:55 AM
ISF4life's Avatar
ISF4life
go to your local hardware to get some just measure it , its came with 2 trims from new. u can replace with 3m tape just cut it long and narrow line.
Old Dec 10, 2019 | 05:06 PM
F_Throttle's Avatar
F_Throttle
I had to take my diffuser on/off once and i was able to pick up a kit with the gaskets on one of the vendors on here.
Old Dec 10, 2019 | 05:26 PM
msgs350's Avatar
msgs350
Can you share which vendor? I've inquired in the past and was told it wasn't sold separately.
@DAng87 I think some members have said they've used gasket/trim from Toyota Camry sport lips. Give that search a try.
Old Dec 11, 2019 | 05:24 AM
jdmek998's Avatar
jdmek998
09180-06296 x6 spacers
09180-06290 x2 spacers both Suzuki part numbers for the rear spacers attach to body.
08F03-SHJ-1100D Honda Rubber molding trim. Get it from Honda dealer or online.
https://www.pegasusautoracing.com/pr...p?Product=6069
7 of these. They get riveted to the front bumper so you can use bolts to hold the lip onto the bumper on.
Now I did not use double sided tape to hold the lip onto the bumper, So i was able to removed freely without issues. I've had my Tom's lip on for about 6 months with no issues.
You will have to source the bolts locally at a hardware store. Here is the link to instructions.
https://www.clublexus.com/forums/is-...it-pieces.html
Old Dec 11, 2019 | 03:52 PM
jspecvtec's Avatar
jspecvtec
Originally Posted by DAng87
Hey everyone,
Thanks!
The edge trim you can get from the toyota dealership. They use a thick mold trim for like the toyota camry sport edition lip kit. i bought mine from dealership for my toms diffuser. I think it was around 20 bucks
Old Dec 12, 2019 | 06:36 AM
NjzFinest's Avatar
NjzFinest
I used this trim on the rear diffuser and it works perfect. It sits on the edge of the lip and looks like it was made for it.
Rear diffuser trim
One roll gives you more than enough.
Old Dec 13, 2019 | 02:58 PM
DAng87's Avatar
DAng87
thanks everyone! i went with the honda edge trim for the diffuser.
for the front i havent gotten a chance to look at it closely yet to see what i need but i will keep you updated and post some pictures!
Old Dec 13, 2019 | 11:31 PM
NjzFinest's Avatar
NjzFinest
U can use the honda trim for the front too i believe. When i bought the toms front lip thats why i got the honda trim but ended up using it for the rear.
GX763
GX - 2nd Gen (2010-2023)
25
May 13, 2025 09:51 AM
jeo0218
Sep 20, 2013 10:16 PM
LEXX135
Mar 28, 2013 11:52 AM
FMYLIFE
IS F (2008-2014)
Feb 15, 2013 08:49 AM
ahmed24
Sep 28, 2011 10:39 AM
