KCLV not increasing
My name is Doug. Little info about my car that may effect in someways.
2008 OB ISF 52k Miles.
Gutted Cats and Muffler delete.
Also has a O2 censor simulator to eliminate CEL lights from gutted Cats.
Will be removing the 02 simulator because i now have the RR Tune
I live in Northern California.
Recently i've got the RR racing handheld tune(https://www.rr-racing.com/RR-Racing-...isftune002.htm)
After applying the tune. I went to monitor my KCLV with a OBD2 Wifi plug. I noticed everytime i accelerates, my KCLV goes down! So i decides to reset my ECU(Negative battery terminal) and test some stuff out. Note i just drove from San Diego back to SF. I've tried lots of stuff while driving. 1st - 4th pulls, 6th - 8th pulls. Also started at a high gear at low speeds and WOT.
I tested the RR Tune 3 times and the Stock Tune 3 times. I need a little help to identify and eliminates the problem. Any help would be greatly appreciated (Please halp me!)
I have done mild researches with the links below:
https://www.clublexus.com/forums/is-...and-power.html
https://www.clublexus.com/forums/is-...tml?styleid=17
*RR Tune
- My KCLV starts out at 15.0 and my KFV at -3.0.
- I managed to bring my KCLV down to 9.9
- Same thing, the more i WOT the more it goes down.
*Stock Tune
- As i WOT my KCLV goes up
- I managed to brought my KCLV up to 16.3 (2nd test)
- I managed to brought it up to 16.8 (3rd test)
- I have not been success in bringing it above 16.8
*My questions are:
- What would be the cause of this?
- Is my KFV supposed to be -3.0?
- Am i ****ed?
- How ****ed am i?
So you would be in 6th going 30-40mph and go up to 70/80mph to increase the KCLV quickly.
I would try a different gas station just to be sure it's not a bad batch of gas and I would also consider running a quality octane booster or mix in some E85 to see if that helps. If the octane boost helps, you likely have too aggressive of a tune or poor fuel (or both). You should also call RR - they are great at trouble shooting and could give you some solid advice/recommendations.
Also KC is always -3 for me and it sometimes drops (-2, -1) under WOT runs on higher gears but returns to -3 when I let off the gas, when that happens my KCLV goes up. The -3 is normal.
I should definitely blend E85 to further diagnose this issue, and see how that goes. Thankk you Sir!
Mine tends to hover around 18-20 but blending to e30 I get it to 21-23 with spirited driving.
I've never needed to got WOT in high gears just to increase KCLV.
Definitely try blending to see if it increases. Good luck!
I then went to monitor my kcvl and it was at 13 something.
Tried resetting etc and would never budge past.
I had a muffler delete with all full bolt ons.
This weekend I changed back to the Joez mufflers. Cleaned my maf, cleaned air filter and the ventilation (larger rr racing intake)
So far so good. Numbers climbing.
Don't know because of the rasp or possible exhaust leak / back pressure etc. I'll report again eventually to see if I get over the 20's again and will re dyno.
If you're limited to 91 gas, add in some Lucas octane booster with 91 Shell/Sunoco/BP etc and after a few miles do some pulls. You should not necessarily go WOT but rather put the engine under heavy load while in a higher gear. An example is getting onto the highway at 45mph and staying in 7-8th and nearly flooring it in manual mode until you get to 80-90. Watch KCLV and KFV. KCLV will tend to go up once KFV drops from -3 anywhere from 0 to -2. Floor it too much and it will go to -4 or -5 and KCLV will drop, so you have to give it enough load for KFV to go positive from -3.
When you go above a certain RPM, say 4k, the KCLV drops, and then goes back to normal when it's not under load. Ask RR if the tune accounts for 91 fuel. Check headers for leaks and maybe have someone look at your car with tech stream to make sure you 02 sensors and AFR are reading correctly.
