Installing Figs rear diff bushings... have some questions
Just knocked this job out. Took me 8 hours going at a very comfortable/slow pace. Hit some snags pulling out the old bushings as expected and removing/reinstalling the axles as there is only so much flex and room to work with. No noticeable increase in NVH.
EDIT: Just took the car on a 450 mile road trip. There is some subtle gear whine at 65-67mph and around 85-90mph. If I could go back in time, I'd pass on this mod.
Did you notice an improvement in the way the rear end feels, particularly during hard acceleration?
I'm totally stock, so its probably just lack of any other noises. The whine is very minute, but I my ears pick it up modulating the throttle. As far as feeling more planted, I am still running the junk economy tires the previous owner put on, so I never had wheel hop to begin with. Perhaps with some sticky tires I'd notice a difference.
I'm really just trying to reduce this on/off throttle slop in the drivetrain. I do a lot of high revving mountain driving modulating the throttle and all my passengers turn into bobble heads during light throttle transitions. There's definitely a lot of play somewhere and my guess is the motor mounts are quite worn.
I arbitrarily used Lucas synthetic 75w-90 this time around.
Motor mounts and maybe carbon drive shaft will help? I’m guessing, the stock driveshaft has to many guibo bushings. It’s a Lexus, all the bushings are designed for comfort. Call figs, they make all replacement bushings and can help you diagnose.
Tech Info Resource
Does it always make the sound or is it throttle dependent?
Tech Info Resource
That's odd. I replaced my spool at the same time I did the bushings, so I expected change, but only found a very slight whine and only on neutral throttle. It's at any speed. Definitely nothing speed dependent on mine. I drive with no music/radio more often than not because I like the native sounds of the car, so I notice the little things very quickly.
