ISF Oil Filter Housing, missing center filter
So first oil change I got on the F was done at the dealership, second my garage. When I removed the oil filter housing I noticed the center filter (not sure what it's really called) was missing. Does anyone know where I can buy just that piece? Or will I have to buy an entire oil filter housing? I'm not sure if the dealership forgot to put it back in or if it was missing when I purchased the car, I'm going to go ahead and assume it doesn't really effect anything since I've been riding around without it for a wile now, but I would like to put it back to the way it should be.
https://www.mylparts.com/oem-parts/l...bC12OC1nYXM%3D
use the clublexus discount to save a few bucks
Yikes! Path of least resistance says the filter captured nothing. The inner seal (the perforated core tube) is spring loaded and keeps the element pressed into housing.
Without it, oil will bypass the filter.
One has to wonder how long it's been gone!!?
How many miles on the vehicle?
Well the good news is the clearance and material quality are pretty good in these engines so it not like they're constantly shedding material. In the 20k mi I've had the 350, I looked at the filter and the bottom of the oil drain pan for signs of material being shed from the engine and there's nothing visible to the eye.
That's not to say there isn't debris in circulation eroding bearings but....
These have an oil pressure gauge, yes? You might just plumb a real gauge in with that and see if there are fluctuations from cold to hot and/or at idle unless the oem isn't normalizing so no one freaks out. They do this with the temp and fuel gauge so they are not moving constantly.
Also a wrecking yard might be a quick solution vs waiting for new cap.
Fingers crossed!
Fingers crossed!
