What is this?
Old May 19, 2018 | 02:33 PM
xaker777's Avatar
xaker777
Default What is this?
so today I installed AOS and meanwhile I am there I cleaned my AFE oil filter, throttle body and maf sensor. While at that I have noticed this.... what is this broken? And do I absolutely have to fix it? Is it the escape plan for my horses?? Please chim in.
Old May 19, 2018 | 02:37 PM
xaker777's Avatar
xaker777
As far as I understand it's a vacuum valve to open secondary intake opening....
Old May 19, 2018 | 02:44 PM
isfvss's Avatar
isfvss
Looks like the plastic tube has broken off the air flap actuator you could try and glue it or just plug up the rubber hose. If you glue it check for air leaks.
Old May 19, 2018 | 02:47 PM
xaker777's Avatar
xaker777
I actually had it while back just forgot to mention it. And I'm in "mechanic" mode so figured I'd ask. Someone somewhere meantion the loss of low end torgue with flap being open... I can always use low end torgue tho...
Old May 19, 2018 | 02:56 PM
xaker777's Avatar
xaker777
Good news, flap thing works. Ill repair it or buy assembly.
Gudder
Nov 8, 2018 10:28 PM
waeel
Oct 25, 2017 05:56 AM
amanda
Nov 18, 2012 12:07 PM
vstolyarov
Apr 13, 2007 04:41 PM
spxChrome
Mar 5, 2003 09:35 PM
