KCLV , obd fusion, 0-60 oh my
Can you send a link to this PIDs? I'm guessing this is directly connected to the OBDlink Device so no need for phone wifi interface correct?
So I only use 93 octane, I’m in Charleston, SC which is sort of hot but nothing like what it will be. I’m running between 90°-100° intake temps. Oil up to operating temperature and coolant temp stabilized. I’ve tried every combination between 1-8 pulls in manual and auto (at least that I can think of). The KCLV started out at 20 and has only moved lower relative to that number but increased and decreased and is currently at 18.72. Does that sound normal. It sounds like everyone seems to be able to keep theirs above 20 with high over gear pulls but that still hasn’t helped me increase it. So, besides additives or finding race gas what else can be done to raise it? How rapidly does it change (I’d imagine it was lean more towards lower numbers of any detections are found and only slowly work back up)?
Bigjon3475 (05-10-18)
Jeebus, I just noticed you're rollin' on 20's, 0-60 OH-MY indeed!!... What wheels are you on? That tire alone is 31lbs (!!!!!!) vs. 22lbs for the R7's I use for track duty, and its MOI has to be CRAZY higher given the added radius... difference in wheel MOI alone is something like 40% vs. 18's assuming similar weights (source: http://www.pro-touring.com/threads/1...mpetition-use?)... If you're not on a light wheel to begin with, you could be talking 60-70% reduction in MOI. If you went to a smaller/lighter setup, say RPF-1's w/R7's or Pirelli slicks, your 0-60 would almost certainly drop to under 4 seconds, given the trifecta bonus of weight reduction, ROLLING weight reduction (and far more impactful than most since you're on 20's), and added traction. Btw, yes I know my R7's are spec'd substantially more narrow, but the set I have is quite wide vs. spec.
Awesome!!! Thanks! To be clear, am I buying directly thru OBDLink app, and if so, is it simply the "Toyota Enhanced Diagnostics" add-on for $9.99?
Adv1’s 20x11 in rear. 20x9.5 in front. So you are saying with some light weight 19’s all the way around it’s in the 11’s? I got my kcvl up to 23.7 at the track
Wow - Great looking setup! Nice wheels to be sure, but I couldn't find much specifics on weight (not even sure I had the right model)... Yes, if you go with something light and small (several 18" packages will clear our brakes, but you have to be careful), the difference in rotating weight is staggering. Could definitely be worth a tenth or three, especially when you include tire weight and compound... Plus, if you decide to track, 18" rubber is much more affordable vs 20". Hence my 18" track setup and 19" for DD.
First, thanks for introducing me to OBD Fusion, I didn’t even know it existed! I downloaded the App and bought the Veepeak BLE.
Second, my KCLV sucks! Under 3K RPM its pretty stready at 15.2 deg. During acceleration, it drops down to 13.2 deg, which I was able to get up to 13.8 deg by doing a bunch of pulls. I cant imagine how Im ever going to see over 20 deg!
Im going to try disconnected my battery, Im interested in seeing if my KCLV will “default” to a better number. I wonder if this low KCLV is a result of my “city” driving. Maybe this is why I did so poorly at the drag strip last year?
Thanks again.
