Correct way to measure brake pad width?
Old Apr 6, 2018 | 08:50 AM
Diesel350's Avatar
Diesel350
Default Correct way to measure brake pad width?
Probably a noob question but is below the correct way to measure how much pad I have left?
Old Apr 7, 2018 | 04:48 PM
B0077144's Avatar
B0077144
I would say, yes.
Old Jun 12, 2019 | 03:08 PM
F_Throttle's Avatar
F_Throttle
Can someone recommend the next best way to measure the pads without removing them? I had my car in for the dash replacement and the dealer told me my pads were at 2mm and I have less than 9k miles on them..
Old Jun 12, 2019 | 04:13 PM
mike33's Avatar
mike33
For the fronts? You can remove the rim and turn the wheel so you can see into the opening on the top of the caliper.
You will be able to determine the amount of pad remaining this way.
Picture from ISF diy brake thread
Old Jun 12, 2019 | 09:21 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
No, this is not how this is done with a caliper. Do it like this:
Old Jun 14, 2019 | 08:53 AM
F_Throttle's Avatar
F_Throttle
I did something wacky.. Took off the wheel and stuck a combination of Uncle Sam's coins between the backing plate at the outer edge of the rotor...... I got ~3.6mm with my caliper... Guessing the rotor's edge is about 0.5-1mm thicker than the face of the rotor where it meets the pads... So let's call it 4mm? Even so, I thought I read these came new at 10mm... How did I burn that much up on street driving? My last set lasted a good 40K+ miles with track days.
Old Jun 18, 2019 | 12:56 PM
AyAyRon's Avatar
AyAyRon
Next time just use a magnet. Same result, but way less hassle.
bt09
Nov 23, 2018 09:52 PM
truthbtold
Jun 8, 2017 07:02 AM
IS3502014
Apr 19, 2015 04:01 PM
MotoX
Suspension and Brakes
May 29, 2011 08:54 PM
carguy07
RX - 1st Gen (1999-2003)
Aug 18, 2007 06:59 AM
