Heater is not blowing hot air
Old 01-04-18, 12:13 AM
blackisF08
blackisF08's Avatar
toping of the coolant is what usually fixes this problem, also make sure to check for valley leak platte if you have isf
Old 01-04-18, 12:14 AM
blackisF08
blackisF08's Avatar
Perfectly normal for sub 40F temperatures. It takes a long time to heat up almost 10 quarts of oil when you're shunting most of the excess heat into the cabin.
after driving my is300 and F back to back i noticed how quick the is300 warms up compared to the F lol, warming up that much oil takes forever
Old 10-15-18, 10:57 AM
Leander311
Leander311's Avatar
Dear God, thank you for today's cold front... and for these forums. Lol. I was SO sad/cold/miserable all the way to work thinking, that of all things my "$80k luxury sports sedan" could have wrong, it'd be the damn heater.
A little water did the deed! Many thanks to all here.
Old 10-15-18, 04:30 PM
Jz39
Jz39's Avatar
When my heat stopped working it was the valley plate leak causing coolant to leak. Yes, you may have fixed it for the time being, but pink goo might be seeping out without you knowing it. I’d get it checked out.
lobuxracer (10-15-18)
Old 10-15-18, 06:15 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Agreed. You shouldn't be losing coolant rapidly. It takes years for coolant volume to fall from evaporation.
Old 10-16-18, 07:02 AM
Leander311
Leander311's Avatar
Thx. Well aware of the dreaded valley plate issue... No seepage yet, thankfully.
I'd flushed the system last year with water, 20% Toyota Super Long Life, and Water Wetter, since coolant is a considerably less effective as a heat transfer medium vs. water. She was just a smidge low, not even a pint, I'm pretty sure from insufficient burping from said flush.
Old 10-18-18, 01:38 PM
Jwconeil
Jwconeil's Avatar
same here. It was the valley plate. This happened to prior owner. Fixed before I purchased.
peterls
24
09-29-19 02:41 PM
thomashmc1
12-18-17 07:29 PM
Jz39
IS F (2008-2014)
12-07-16 05:11 PM
2010ISF
IS F (2008-2014)
03-20-16 10:29 PM
mmarzluf
07-04-10 01:38 PM
Quick Reply: Heater is not blowing hot air
