Brake grooves/warping problem?
Old Aug 4, 2017 | 03:39 PM
DCoolBeans's Avatar
DCoolBeans
Check and see if the holes are junked up.
If yeah then get a drill bit and free those holes by poking them through to unclog em
Old Aug 5, 2017 | 10:49 AM
flowrider's Avatar
flowrider
Veteran: Air Force
I guess that's another reason to stay away from drilled rotors And another reason Lexus went to slotted rotors on the GSF and RCF
Lou
Old Aug 5, 2017 | 10:48 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Lou
Indeed. There is nothing good about drilled rotors at all. Yes, this wear pattern is completely normal, I have four sets of front rotors using OEM pads, Carbotech 1521s, Project Mu HC+800s, and occasionally Carbotech XP12s all showing the same wear patterns.
Ask yourself a few important questions:
1. Does the car stop predictably from all speeds?
2. Does the appearance of the brake discs impact their mechanical performance?
3. Is it worth money to replace something because it works well, but does not look the way I think it should?
The answers to these questions will guide you to what you need to do next. Personally, I couldn't care less what the brakes look like as long as they stop the car predictably. YMMV.
chucktaylu
Jan 26, 2018 07:47 PM
shikbas
Apr 11, 2015 01:29 PM
Slvr surfr
Wheels, Tires & Brakes Forum
Aug 13, 2014 10:09 PM
Suneet
Mar 24, 2004 11:57 AM
bLingIn3o0
Suspension and Brakes
Oct 28, 2003 04:31 PM
