Help me solve an odd braking problem...
Hey guys - I have a 2010 ISF that has an odd brake noise. When the car is making very slow tight turns (I notice it most on left hand turns), the car almost stutters the rear driver side brake. I took it into the dealer to have them check it out, I suspected its something with the ABS as it almost sounds like an abs pulse (although i dont get a light on the dash, nor do i see the VCS/TRC light). They said its from the tires... i recently had new tires put on it (the problem existed prior to putting on the new tires. This evening i had my wife drive the car to reproduce the issue and the driver rear wheel is litterally pulsing when making the tight left hand turn. I took a video of the issue, I'm hoping someone can point me in the right direction. I have a Techstream cable/software and it looks like the ABS system doesn't have an code present, and the sensors are all reading for the ABS sensors (i see data for all 4 wheels). The car runs very strong, no other issues at all. Service is all current, recently had the rear diff oil replaced (the issue persisted before and after). Any ideas?
Thanks!
Andrew
Thanks!
Andrew
I think it's a design flaw in the body and the amount they allow the steering wheels to turn. Mine does this too. Remember that they took an IS chassis and tried to cram a V8 in it! They had to make the front wider which made for some wheelbase steering issues. Just don't turn your wheel all the way.
Edit
OK just watched the video and is not supposed to do that. I don't know.
Edit
I had the same noise. It drove me nuts. Ended up being a small pebble that got lodged in my caliper and was rubbing the rotor. I thought it was my wheel bearing as well but was able to pinpoint the location of the noise by putting my car up on jack stands and turning the wheel.
The noise does not persist when driving straight, or if speed is increased. I don't get any noise when driving at speed (anything above slow turns), just when slow speed turns. I'll look at the dust shield, I felt the wheel/rim when I took the video and the rim is stuttering like something is grabbing it, either brake / hitting something or I also suspect a wheel bearing.. or perhaps something in the halfshafts/lsd.
I haven't had it up myself to check brakes or see if it has any play in the bearing but I figured either of those issues would probably result in louder noises as speed increased. I'm a bit irritated the dealer said 'it's your tires' when it's clearly a metal on metal noise. Frustrating I have to do their job troubleshooting, especially when it's under warranty.
Edit
Edit
Jack up the car, take the wheel off. Check the brake dust shield to make sure they didn't dent it, check for any foreign bodies in the calipers (tree branch or something else).
2. Check the CV joints for any tears.
Put the wheel back on, roll it with your hand, see if you can reproduce the noise again.
Check the torque on the lug-nuts, should be 67 ft-lbs.
I wanted to follow up - so i pulled both wheels off and rotors, no rocks or debris that i could see causing the issue, no obvious grinding marks, half shafts boots were good. I did notice that the rotors were very worn (original to the car @ 90k miles). I ordered and replaced them today and that seems to have solved the issue
I'd have figured the dealer would have been more than happy to sell me new rotors... i'm guessing they never even took the wheels off. Anyways - glad its fixed and i appreciate all the suggestions.
I purchased an installed original brake rotors (Part Number 424310W030) in case anyone is curious
They are a steal at $105 on amazon
