Radiator Options
Old Jan 18, 2019 | 11:16 AM
  #31
FIGS's Avatar
FIGS
The Maker
FWIW the trans passage in the factory radiator is actually a preheater for the trans fluid, not a cooler. There is a separate stand-alone cooler as well. That is a great price on the radiator from tuner sports as well.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old Jan 18, 2019 | 01:30 PM
  #32
sleepstate's Avatar
sleepstate
Good point Mike. Exactly why I don't get any heartburn over losing that part with a new radiator install.
Old Jan 18, 2019 | 01:32 PM
  #33
Wh0pp3r's Avatar
Wh0pp3r
Mike
So would you just loop the lines then?
any temp issues?
Old Jan 22, 2019 | 08:29 AM
  #34
FIGS's Avatar
FIGS
The Maker
You would bypass the connection through the stock rad core. One of my customers was the first to test this in CA and given the weather he has not experienced any issues for the last 2 years daily driving.
Mike
__________________
Old Jan 22, 2019 | 10:52 AM
  #35
Wh0pp3r's Avatar
Wh0pp3r
Mike
Sorry, i mean. if i replace the oem unit with this koyorad. on the transmission side, do you just loop the lines that would go to the radiator or plug em somehow?
Old Jan 22, 2019 | 12:15 PM
  #36
McPierson's Avatar
McPierson
I can’t speak to the “correct” track proof solution, but the stock setup pumps to the radiator then to the separate trans cooler. So you just send it to the expernal cooler. RR sells a separate external cooler to replace the OEM external cooler.
Old Jan 22, 2019 | 01:59 PM
  #37
lobuxracer's Avatar
lobuxracer
Tech Resource
The radiator loop is there to stabilize the temperature. If the transmission fluid is hotter than the engine coolant - which is more often than you might want to believe - the radiator will dissipate heat from the transmission. If the transmission fluid is cooler than the coolant, it will absorb heat from the coolant. In either case, once this happens, the fluid goes through an air/oil heat exhanger (looks like a small radiator in front of the radiator), so no matter what, heat will be extracted from the transmission fluid. If you bypass the radiator portion entirely, you might experience a wider range of temperatures in your ATF. Depending on where you live it might present service life issues for your ATF.
There is small benefit to removing the radiator from the circuit - you'll have a little more capacity to remove heat from the coolant because you won't be loading it with heat from the transmission too. And, if you are super worried about your ATF temperatures, you can just buy a Tundra transmission cooler and stuff it in the same spot the OEM cooler is for added capacity - or something else.
My only concern with putting any bigger heat exchanger in front of the radiator is reducing the radiator's ability to shed heat from the coolant at full load. I seriously doubt you'd ever have a problem on a street driven vehicle, but at the track it might be problematic.
If it were my choice, I'd bypass the radiator loop in a heartbeat, and monitor ATF temperature at the track just to be sure all is well.
Old Jan 22, 2019 | 02:41 PM
  #38
Wh0pp3r's Avatar
Wh0pp3r
FUNNY YOU SAY THAT!
I was just looking at tundra coolers lol!
Old Feb 5, 2021 | 09:55 PM
  #39
speeddem0n's Avatar
speeddem0n
Does anyone know why the koyorad hh012170 says 2008-2011 ISF and doesn’t include 2012+? Is there a difference and it won’t fit?
Old Feb 6, 2021 | 05:20 AM
  #40
Scott610's Avatar
Scott610
I have the koyo radiator but RR-Racing installed it . What I would do is a comparison before buying it . Try to get pictures of both radiators make shure all the fittings and piping fits or where they should be . Good luck
Old Feb 6, 2021 | 08:26 AM
  #41
FIGS's Avatar
FIGS
The Maker
The overflow hose is larger on the late model. We offer an adapter with our kit to make it work on all model years. Mike
https://www.shopfigs.com/v3/index.ph...ch=IS-F%20koyo
EDIT: Sorry realized it did not make it to the options although we have sold the solution to customers.
listing options added and attached pics.
__________________
Old Feb 6, 2021 | 02:03 PM
  #42
Meurz's Avatar
Meurz
This would replace the OEM external cooler as per Setrab/Mocal/whatever in the RRR kit, right? Could you share the Tundra cooler P/N? Thanks.
Old Feb 6, 2021 | 07:03 PM
  #43
lobuxracer's Avatar
lobuxracer
Tech Resource
Tundra P/N is 32910-0C010. Might take some clevering to make it fit and work, but it's way bigger. I did a quick eyeball with a friend's Tundra and it looked pretty likely to work, but I can't say I've actually fit one.
Old Feb 6, 2021 | 10:16 PM
  #44
Joe Z's Avatar
Joe Z
Lightbulb
Good catch Mike...!!!
This thread discusses the IS F radiator differences in depth.
Thread link below.
Radiator Differences
Joe Z
Old Feb 8, 2021 | 07:05 PM
  #45
speeddem0n's Avatar
speeddem0n
Thank you for the clarification! I wondered why no one asked this.. is that because the 2012 and up radiators are not as likely to fail?
So far mine seems good but I just ordered a Koyo to keep aside just in case. They’ve recently been sold out almost everywhere I checked online but saw them back in stock this morning and bought one. Thanks again for your reply.
EDIT: no option to buy it separately on the website, will it be added soon if I want to buy it?
Also I guess I can always measure it but do you know what the measurements of both ends are?
