o2 sensor seized
Old Dec 4, 2016 | 08:44 AM
DroCityLex's Avatar
DroCityLex
Default o2 sensor seized
so after having my borla exhaust installed yesterday the guy at the shop tells me my left o2 sensor is seized... there is no threading left it basically looked melted. do i need to replace it or can i go somewhere else to get it fixed?
Old Dec 4, 2016 | 09:29 AM
Fivepoint0's Avatar
Fivepoint0
Best to just replace it.
Old Dec 4, 2016 | 11:34 AM
Helo58's Avatar
Helo58
Kind of an important distinction between seized and melted. Melted is indicative of a possibly more significant problem (lean condition) than a stuck O2 sensor. New one is the safe bet.
Old Dec 4, 2016 | 06:53 PM
DroCityLex's Avatar
DroCityLex
any sites to check for oem o2 sensor?
Old Dec 4, 2016 | 08:01 PM
BLKLBL's Avatar
BLKLBL
One of my O2 sensors stripped when installing my Borla. I got a new Denso brand from Rockauto.com for half of what the dealer wanted
Old Dec 5, 2016 | 05:13 AM
DroCityLex's Avatar
DroCityLex
thanks bud, how about getting it replaced? should i go to dealer and pay labor?
Old Dec 5, 2016 | 06:38 AM
nicklausw's Avatar
nicklausw
You can OE Denso on Amazon for a good price.
Old Dec 5, 2016 | 08:22 AM
BLKLBL's Avatar
BLKLBL
To replace it you'll need to pull back the carpet along the center console, plug the new one in, fish the new wire thru the grommet in the floor, and then jack up the car, put it on stands, and install the sensor in the exhaust with the special socket tool.
Old Dec 5, 2016 | 05:56 PM
DroCityLex's Avatar
DroCityLex
should I replace both or just the bad one? rockauto suggests you do both.
Old Dec 5, 2016 | 08:57 PM
msgs350's Avatar
msgs350
you only need to do 1 but do both if it makes you feel better. The sensors are fairly priced..around $70?
Old Dec 6, 2016 | 06:12 AM
BLKLBL's Avatar
BLKLBL
Its recommended to replace both if one is malfunctioning. Since you're replacing due to stripped threads from exhaust changeover, you should be fine with just doing one.
Old Dec 6, 2016 | 07:43 AM
ISFMichael's Avatar
ISFMichael
The shop that was installing my borla couldn't get my o2 sensors off as well, said they were seized on there. So they ordered a couple o2 sensors to replace them. But they ended up not having to use them as after a lot of hard work the oe sensors finally came off.
Old Dec 6, 2016 | 02:45 PM
DroCityLex's Avatar
DroCityLex
the shop stuggled with the left one and came to find out it was seized. they repaired the threading on the exhaust and temporarily plugged it until i get a new sensor. No check engine light so far though.
Old Dec 7, 2016 | 08:58 AM
4TehNguyen's Avatar
4TehNguyen
If you live up north and unsure if they are seized/rusted could buy a couple of extra sensors to install on your new exhaust, and dont even try to remove the ones in the stock pipe. Then its just plug and play when you want to change back. Also avoid the risk of over twisting the O2 sensor wiring or cross threading during install
Old Dec 7, 2016 | 09:04 AM
virulosity's Avatar
virulosity
This surprised me that they don't have a connector underneath the car when I changed out my exhaust. Pretty bad design practice. Luckily mine were ok.
