Bluetooth audio/ iPhone Volume
Old Sep 30, 2016 | 02:34 PM
USBM2011's Avatar
USBM2011
Default Bluetooth audio/ iPhone Volume
Hey all, not sure if this will be news to anyone, but was to me.....
Ever since I got my 2011 ISF (has blue tooth streaming audio) i've noticed the volume of the ISF ML stereo was super quiet, like even at MAX volume it was loud, but not like blaring loud as you'd expect when at MAX volume (not that i want to drive around with it at max anyway), but i was wondering if it was the bluetooth being weak or what because through the radio or CD player it could go much louder than with iPhone streaming from apple radio, because i had the volume on phone all the way up.....
Well i figured out its a setting in the phone called "sound check" under the settings in the Music/iTunes/radio app.
I un-checked "sound check" and realized it was the phone that was limiting the volume output of songs in my library and streaming, because the purpose of sound check was to standardize the volume of all your library to the same volume, the problem is if you happen to have a song in your phone that at the time of recording was much quieter than another it would put all your songs at that quieter volume, so you'd basically have to have it all the way up, and the rest of the songs would be much quieter.
Like i said not news to some, and irrelevant to some, but its been bugging me since i got this car that the bluetooth audio was so weak....
Old Sep 30, 2016 | 04:17 PM
Tom2769's Avatar
Tom2769
AhHa! if you were in AZ, I'd buy you a beer. Mine was doing the same, but not anymore - much thanks.
Old Sep 30, 2016 | 04:37 PM
kzlflash's Avatar
kzlflash
(MY2011) My problem is that the music volume is much lower, until I make or receive a phone call. After that it jumps back up to how it "normally" sounds. I say normal because my music use to be much louder.
I also checked and my sound check is off.
Anyone have the same problem and found a solution?
Old Sep 30, 2016 | 06:59 PM
USBM2011's Avatar
USBM2011
Mine did that also, i find it to be intermittent though, the solution i found was to turn up the bluetooth phone volume all the way prior to ending a phone call if possible. not sure if it actually works but it seemed to ? could be my imagination...
LizF
RX - 4th Gen (2016-2022)
17
Jun 3, 2022 03:04 PM
bobett
May 16, 2019 05:12 PM
celledge73
LX - 3rd Gen (2008-2021)
Apr 26, 2018 06:19 AM
jkeifer3
RC F (2015-present)
12
Apr 11, 2016 02:51 PM
LisaES350
Jan 31, 2013 07:48 AM
