Turbo isf
Old May 13, 2016 | 10:11 AM
  #31
zazzn's Avatar
zazzn
Originally Posted by ultimase
Coming from a turbocharging background I'm watching this with a bit of interest. Kinda ironic that I've stumbled into this thread when I'm actually trying to get away from turbo's and onto displacement. But I supposed power is still power.
I'm wondering why no one has even tried with a simple fuel pressure riser. It's not the best way of doing things, but it should get you by for relatively low boost. The only issue there would be controlling timing. But again for low boost applications it's cheap and relatively safe.
As for volumetric efficiency sizing the turbo is really a few calculations and compressor maps away. Not extremely difficult, but does take some time and knowing some information regarding the motor. If you can think of an application there will likely be an off the shelf turbo that can do it, probably even a turbo that's being used on a oem application.
If only it was that simple. The problem is the ECU will fiddle with fuel not matter what you do with fuel pressure. Then there's the fact that you have direct injection as well for partial boot situations. Bottom line, is unless you trick the W/B 02 sensors by feeding back wrong values to keep the car richer for boosted operation nothing is going to work short of cracking the computer. Now, even if you do trick the 02 sensors there is only so much overhead in the fueling map on the computer.
Old May 13, 2016 | 11:37 AM
  #32
ultimase's Avatar
ultimase
Now that's interesting, this might be a dated approach, but normally the wot values are hard coded in the ECU, or at least it used to be. At wot and high RPM's ecu's used to ignore o2 input and mostly rely on rpm and maf readings, things are normally happening too fast at that point to rely on downstream readings.
Though I will be the first to admit, this was from past experience with ecu's and boost from 2000-2010ish. I've been out of the loop quite a bit more recently.
This is sadly where the rarity of the isf is a downfall. A more popular platform would have piggybacks or standalones that could probably find a work around. Rather we have only a few companies trying to crack the code to an ecu on a vehicle that's been out of production for 2 years.
Old May 13, 2016 | 04:56 PM
  #33
FFM's Avatar
FFM
Supercharger is the way to go with this application. Turbos would be for show, much like the couple if not only one I know of on this forum. Rear mounted is also very inefficient for such a low power output so makes the system again, just show.
You would get better gains and better transient response out of a supercharger.
**** Greddy already has one developed. Someone should buy one and just have TTFS or RR tune it.
Old May 15, 2016 | 03:52 PM
  #34
Meraki Autoworks's Avatar
Meraki Autoworks
Your #1 Lexus Vendor
RR-Racing just sent me some pics of the supercharger... I'm so excited...
-Josh
__________________
Orange County, CA
Text/Call: 213 394 2886
Old May 15, 2016 | 04:43 PM
  #35
Bigjon3475's Avatar
Bigjon3475
-Josh
That's some BS...
Old May 15, 2016 | 04:49 PM
  #36
Meraki Autoworks
Originally Posted by Bigjon3475
That's some BS...
-Josh
__________________
Orange County, CA
Old May 15, 2016 | 04:50 PM
  #37
Bigjon3475's Avatar
Bigjon3475
-Josh
Pics or it didn't happen!
Old May 15, 2016 | 04:53 PM
  #38
Meraki Autoworks
I wish I could.. Time is patience!!
-Josh
__________________
Orange County, CA
  #39
MileHIFcar's Avatar
MileHIFcar
-Josh
Tease!.........
Old May 15, 2016 | 04:55 PM
  #40
Meraki Autoworks
Originally Posted by MileHIFcar
Tease!.........
Knowing the details of it too... Oh gosh.
-Josh
__________________
Orange County, CA
Old May 16, 2016 | 07:00 AM
  #41
Evil Teo's Avatar
Evil Teo
I'm sure quite a few people got the tease to Josh......excited for Rafi for some more good news to come....
Scott610
IS F (2008-2014)
Oct 10, 2015 09:05 PM
ryanlexus7
RC F (2015-present)
May 2, 2015 09:45 AM
ItsanF
IS F (2008-2014)
Feb 23, 2012 02:22 PM
TXCarguy
IS F (2008-2014)
Oct 27, 2011 07:18 AM
sksc1105
IS F (2008-2014)
34
Sep 20, 2011 07:56 AM
