Shaky Headlights when going over bumps....
Old Oct 15, 2015 | 04:00 PM
Kojak77's Avatar
Kojak77
Yea, mine do the same thing.
Old Oct 15, 2015 | 06:03 PM
dcguy's Avatar
dcguy
Hmm, seems to be a pretty common issue. When I've seen this issue the lowbeam bulb it was seated properly with the clip, its the entire projector assembly that seems to wiggle around. Movement to the touch, or bump, but always returns to its original resting place. Perhaps its an afs thing, but was under the assumption that they were locked with gears of some sort and the motor wouldn't allow any movement. I had this issue with my is250 and but wouldn't excessively shake over small cracks and tar seals on the road that some may have had issues with.
Old Oct 16, 2015 | 09:33 AM
PatrickISF's Avatar
PatrickISF
I know the 2008-2010 models have AFS which will make the headlight shake a little over bumps. The 2011+ years probably won't experience this since their headlights are fixed, no more AFS. Someone backed into my front bumper on the passenger corner awhile back. Body shop got it fixed but noticed bad vibration coming from the passenger headlight when going over bumps. Took it back and they ended up having to order a headlight bracket since mine was broken. Once they did that it's not shaking anymore. Mine will shake a little under really crappy roads but I know with the cars stiff suspension you have to expect that.
Old Oct 16, 2015 | 10:04 AM
Kojak77's Avatar
Kojak77
I have a 2011, the headlights shake on crappy roads and serious bumps.
Old Oct 16, 2015 | 04:32 PM
v8sedan's Avatar
v8sedan
Same here, seems normal
Nebel
Apr 10, 2019 12:47 PM
JDMV8
IS F (2008-2014)
15
May 22, 2012 07:22 PM
Hit Man X
Nov 3, 2005 04:24 PM
