Questions about Jack Points
Old Sep 8, 2015 | 11:16 PM
scsisf's Avatar
scsisf
Originally Posted by SoCalISF
After purchasing several different jack adapters, I settled on these as my favorite....
http://www.ebay.com/itm/331441745431?
_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I now keep one on top of the spare for when I am changing wheels and tires at the track, and one in my roll cab. The others will be used when necessary, but these work exceptionally well. Simple, will not scratch, and very inexpensive.
I just ordered one myself! I worked on the car this weekend and became very frustrated with the lack of jacking points underneath the car.
Old Sep 9, 2015 | 10:26 AM
kukimonsta's Avatar
kukimonsta
great find!
Old Sep 13, 2015 | 08:25 AM
clarionguy's Avatar
clarionguy
How do you guys find the fitment?
The same seller is advertising this one now:
http://www.ebay.ca/itm/LEXUS-IS250-I...item35e05394d5
the slot has a slight angle cut to it .. wondering if this would be better
Old Sep 13, 2015 | 11:12 AM
H1_OFICR's Avatar
H1_OFICR
Pardon my ignorance but I still am slightly confused.. I understand the rear jack point and then you can place the stand under car right in front of the rear wheels.. But if I want to raise the entire front end with no ramps, where does everyone put the stands if the pinch welds are currently being occupied by the jack itself.
Old Sep 13, 2015 | 11:27 AM
VTsuckah's Avatar
VTsuckah
Before i bought race ramps, I used the frame rather than the pinch welds to jack the car up, then use the jacks on the pinch welds. As long as you are carefuk with the placement of the jack, your frame will not get bent or damaged. Otherwise, I use race ramps then jack the car up at the front center jack point if I need to get more clearance underneath. Race ramps are a great investment IMO.
Old Sep 14, 2015 | 05:38 AM
mikersoft's Avatar
mikersoft
In that case, lift the whole front at once using the jack point in front of the oil pan.
https://www.clublexus.com/forums/is-...ack-point.html
Old Sep 14, 2015 | 01:59 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Unless you have a very low profile jack, you'll need some help getting the front high enough to fit the jack underneath. I use ramps I made from a 2 x 10. I just cut it into four pieces so it ramps up to double thickness and I can get the jack under the car without any issues.
Old Sep 18, 2015 | 07:13 AM
Rickna's Avatar
Rickna
Very close to what I did with the wood ramps. I can easily get to the center jack point, and then use stands.
Old Sep 18, 2015 | 07:38 AM
FIGS's Avatar
FIGS
The Maker
We also offer our FIGS JACKJAW which is made to fit under the sideskirt of the F and not have jack interference. The urethane interface keeps the rail aligned.
https://vimeo.com/61929987
http://shopfigs.com/v1/index.php?rou...product_id=188
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old Sep 18, 2015 | 12:21 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Same thing here, slightly different execution. I glued and screwed it together with deck screws.
Old Sep 18, 2015 | 12:49 PM
Rickna's Avatar
Rickna
It'll do the job! The reason I went with 2x4's was to reduce weight. I have spinal damage.
Old Sep 18, 2015 | 01:54 PM
xaznx's Avatar
xaznx
Just ordered a jack jaw, thanks figs!!
AZN Lex
Nov 1, 2015 08:43 AM
smokyis350
Apr 5, 2015 09:18 AM
ISmak4
Mar 25, 2013 02:31 PM
SoCal Cyco
Apr 21, 2010 05:50 PM
manta8888
Dec 20, 2006 08:37 PM
