ISF Data Logging
Old Mar 29, 2015 | 03:16 PM
juanmedina's Avatar
juanmedina
Default ISF Data Logging
Is it possible to data log the ISF?
I want to be able to data log my car and use a program like Virtual dyno from my subaru days to estimate my horse power changes as I mod the car.
From people that don't know Virtual Dyno is a software that you use your car data logs to estimate the car horse power. It is used extensively in the Subaru and EVO forums for road tuning. It has been developed and is proven to read within 5% of a Dynojet. I also prefer the Virtual Dyno because you get real world airflow. The only potential issue that I see is that the 1:1 gear for the ISF is 6th gear and I don't think I can do a wide open pull to red line on the street . A second or third gear will do since I am just trying to see the change in horse power as I mod my car.
http://www.virtualdyno.net/
I am able to connect to the ECU with the Torque App and see throttle position, RPM, coolant temp, etc etc; but I wonder if there is anything else that I can use to log the car at a higher refresh rate.
Old Mar 30, 2015 | 01:35 PM
Vervish's Avatar
Vervish
I was an avid tuner of my Suby - I used the log interpolation excel sheet for all my tuning needs - including the road dyno.
The excel sheet (http://api.viglink.com/api/click?for...%2520Jan08.zip) allows you to manipulate the gear ratio, aero, and weight - which once adjusted, should bring it theoretically close to accurate for the F.
The data required is just time and RPM to work.
Old Mar 30, 2015 | 02:43 PM
juanmedina's Avatar
juanmedina
In the beginning of my suby days I used to love Airboy's road dyno . I end up using VD in the end since is used in many different platforms. I will try to see if I can get to with the IS-F later today.
Keep in mind that Airboy reads like a low reading mustang dyno
Old Mar 30, 2015 | 03:05 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
If it accurately predicts your car's performance, who cares what the numbers are. You can lie about the numbers, lots of guys do.
Old Mar 30, 2015 | 05:50 PM
juanmedina's Avatar
juanmedina
I am going to the track this Thursday. I just want to get an idea how much hp do I need for certain trap speed. And like I said before is a great tool for tracking progress without going to the dyno.
I agree with you a lot of people lie, they change correction factors, smoothing etc etc. The drag strip tell the real story.
Well I got it to work but I need something that has a higher logging rate. I also had to spend sometime figuring out how to convert the time stamp to what Airboy requires. For some reason my throttle is not 100% the log it says 80%
My car is a 2008 with muffler and secondary cat deletes it also has light weight 18" wheels.
So here is the plots:
Here is log
Code:
 Device Time	GPS Speed (Meters/second)	Speed (GPS)(mph)	Engine Load(%)	Engine Coolant Temperature(°C)	Engine RPM(rpm)	Speed (OBD)(mph)	Mass Air Flow Rate(g/s)	Timing Advance(°)	Throttle Position(%)
100.000	9.75	21.81012851	97.64706421	92	1851.50	22.37	64.00	29.00	52.94117737
200.000	9.75	21.81012851	97.64706421	92	1851.50	22.37	64.00	10.00	80.78431702
300.000	9.75	21.81012851	98.03921509	92	1851.50	22.37	64.00	10.00	80.78431702
400.000	9.75	21.81012851	98.03921509	92	2033.50	22.37	64.00	10.00	80.78431702
500.000	9.75	21.81012851	98.03921509	92	2033.50	24.23	74.93	10.00	80.78431702
600.000	9.75	21.81012851	98.03921509	92	2033.50	24.23	74.93	8.50	80.78431702
700.000	11.25	25.16553399	97.64706421	92	2033.50	24.23	74.93	8.50	80.78431702
800.000	11.25	25.16553399	97.64706421	92	2238.25	24.23	74.93	8.50	80.78431702
900.000	11.25	25.16553399	97.64706421	92	2238.25	26.10	80.04	8.50	80.78431702
1000.000	11.25	25.16553399	97.64706421	92	2238.25	26.10	80.04	13.50	80.78431702
1100.000	11.25	25.16553399	95.6862793	92	2238.25	26.10	80.04	13.50	80.78431702
1200.000	11.25	25.16553399	95.6862793	92	2444.50	26.10	80.04	13.50	80.78431702
1300.000	11.25	25.16553399	95.6862793	92	2444.50	26.10	90.32	13.50	80.78431702
1400.000	11.25	25.16553399	95.6862793	92	2444.50	26.10	90.32	15.00	80.78431702
1500.000	11.25	25.16553399	97.64706421	92	2444.50	26.10	90.32	15.00	80.78431702
1600.000	11.25	25.16553399	97.64706421	92	2672.50	26.10	90.32	15.00	80.78431702
1700.000	14	31.31710754	97.64706421	92	2672.50	29.20	90.32	15.00	80.78431702
1800.000	14	31.31710754	97.64706421	92	2672.50	29.20	100.15	14.50	80.78431702
1900.000	14	31.31710754	96.86274719	92	2672.50	29.20	100.15	14.50	80.78431702
2000.000	14	31.31710754	96.86274719	92	2853.00	29.20	100.15	14.50	80.78431702
2100.000	14	31.31710754	96.86274719	92	2853.00	32.31	110.96	14.50	80.78431702
2200.000	14	31.31710754	96.86274719	92	2853.00	32.31	110.96	16.00	80.78431702
2300.000	14	31.31710754	98.03921509	93	2853.00	32.31	110.96	16.00	80.78431702
2400.000	14	31.31710754	98.03921509	93	3078.00	32.31	110.96	16.00	80.78431702
2500.000	14	31.31710754	98.03921509	93	3078.00	34.80	116.76	16.00	80.78431702
2600.000	14	31.31710754	98.03921509	93	3078.00	34.80	116.76	20.00	80.78431702
2700.000	17.5	39.14638621	98.8235321	93	3078.00	34.80	116.76	20.00	80.78431702
2800.000	17.5	39.14638621	98.8235321	93	3294.50	34.80	116.76	20.00	80.78431702
2900.000	17.5	39.14638621	98.8235321	93	3294.50	38.53	129.35	20.00	80.78431702
3000.000	17.5	39.14638621	98.8235321	93	3294.50	38.53	129.35	19.50	80.78431702
3100.000	17.5	39.14638621	100	93	3294.50	38.53	129.35	19.50	80.78431702
3200.000	17.5	39.14638621	100	93	3524.00	38.53	129.35	19.50	80.78431702
3300.000	17.5	39.14638621	100	93	3524.00	42.25	141.53	19.50	80.78431702
3400.000	17.5	39.14638621	100	93	3524.00	42.25	141.53	19.50	80.78431702
3500.000	17.5	39.14638621	99.60784149	93	3524.00	42.25	141.53	19.50	80.78431702
3600.000	17.5	39.14638621	99.60784149	93	3719.50	42.25	141.53	19.50	80.78431702
3700.000	20.75	46.41642746	99.60784149	93	3719.50	45.36	141.53	19.50	80.78431702
3800.000	20.75	46.41642746	99.60784149	93	3719.50	45.36	156.96	18.00	80.78431702
3900.000	20.75	46.41642746	100	93	3719.50	45.36	156.96	18.00	80.78431702
4000.000	20.75	46.41642746	100	93	3719.50	45.36	156.96	18.00	80.78431702
4100.000	20.75	46.41642746	100	93	3980.25	45.36	156.96	18.00	80.78431702
4200.000	20.75	46.41642746	100	93	3980.25	45.36	175.21	15.00	80.78431702
4300.000	20.75	46.41642746	100	93	3980.25	45.36	175.21	15.00	80.78431702
4400.000	20.75	46.41642746	100	92	4217.75	45.36	175.21	15.00	80.78431702
4500.000	20.75	46.41642746	100	92	4217.75	48.47	187.29	15.00	80.78431702
4600.000	20.75	46.41642746	100	92	4217.75	48.47	187.29	14.50	80.78431702
4700.000	24	53.68646872	100	92	4217.75	48.47	187.29	14.50	80.78431702
4800.000	24	53.68646872	100	92	4421.75	48.47	187.29	14.50	80.78431702
4900.000	24	53.68646872	100	92	4421.75	52.82	206.09	14.50	80.78431702
5000.000	24	53.68646872	100	92	4421.75	52.82	206.09	15.00	80.78431702
5100.000	24	53.68646872	98.8235321	92	4421.75	52.82	206.09	15.00	80.78431702
5200.000	24	53.68646872	98.8235321	93	4669.50	52.82	206.09	15.00	80.78431702
5300.000	24	53.68646872	98.8235321	93	4669.50	56.54	216.10	15.00	80.78431702
5400.000	24	53.68646872	98.8235321	93	4669.50	56.54	216.10	13.50	80.78431702
5500.000	24	53.68646872	98.03921509	93	4669.50	56.54	216.10	13.50	80.78431702
5600.000	24	53.68646872	98.03921509	92	4895.25	56.54	216.10	13.50	80.78431702
5700.000	27.5	61.51574975	98.03921509	92	4895.25	60.27	227.76	13.50	80.78431702
5800.000	27.5	61.51574975	98.03921509	92	4895.25	60.27	227.76	14.50	80.78431702
5900.000	27.5	61.51574975	98.03921509	92	4895.25	60.27	227.76	14.50	80.78431702
6000.000	27.5	61.51574975	100	92	4895.25	60.27	227.76	14.50	80.78431702
6100.000	27.5	61.51574975	100	92	4895.25	60.27	227.76	14.50	80.78431702
6200.000	27.5	61.51574975	100	92	4895.25	60.27	227.76	14.50	80.78431702
6300.000	27.5	61.51574975	100	92	5281.25	60.27	227.76	14.50	80.78431702
6400.000	27.5	61.51574975	100	92	5281.25	64.00	251.03	14.50	80.78431702
6500.000	27.5	61.51574975	100	92	5281.25	64.00	251.03	15.50	80.78431702
6600.000	27.5	61.51574975	98.8235321	92	5281.25	64.00	251.03	15.50	80.78431702
6700.000	31.25	69.90426108	98.8235321	92	5563.25	64.00	251.03	15.50	80.78431702
6800.000	31.25	69.90426108	98.8235321	92	5563.25	67.73	251.03	15.50	80.78431702
6900.000	31.25	69.90426108	98.8235321	92	5563.25	67.73	259.29	15.00	80.78431702
7000.000	31.25	69.90426108	95.6862793	92	5563.25	67.73	259.29	15.00	80.78431702
7100.000	31.25	69.90426108	95.6862793	92	5563.25	67.73	259.29	15.00	80.78431702
7200.000	31.25	69.90426108	95.6862793	92	5786.50	71.46	259.29	15.00	80.78431702
7300.000	31.25	69.90426108	95.6862793	92	5786.50	71.46	267.89	13.50	80.78431702
7400.000	31.25	69.90426108	95.6862793	92	5786.50	71.46	267.89	13.50	80.78431702
7500.000	31.25	69.90426108	96.86274719	92	5786.50	71.46	267.89	13.50	80.78431702
7600.000	31.25	69.90426108	96.86274719	92	5989.75	74.56	267.89	13.50	80.78431702
7700.000	34.5	77.17430234	96.86274719	92	5989.75	74.56	284.82	12.50	80.78431702
7800.000	34.5	77.17430234	96.86274719	92	5989.75	74.56	284.82	12.50	80.78431702
7900.000	34.5	77.17430234	99.60784149	92	5989.75	74.56	284.82	12.50	80.78431702
8000.000	34.5	77.17430234	99.60784149	92	6218.75	74.56	284.82	12.50	80.78431702
8100.000	34.5	77.17430234	99.60784149	92	6218.75	78.91	289.14	12.50	80.78431702
8200.000	34.5	77.17430234	99.60784149	92	6218.75	78.91	289.14	14.00	80.78431702
8300.000	34.5	77.17430234	100	92	6218.75	78.91	289.14	14.00	80.78431702
8400.000	34.5	77.17430234	100	92	6442.75	78.91	289.14	14.00	80.78431702
8500.000	34.5	77.17430234	100	92	6442.75	82.64	291.54	14.00	80.78431702
8600.000	34.5	77.17430234	100	92	6442.75	82.64	291.54	15.00	80.78431702
8700.000	37.75	84.4443436	98.4313736	92	6442.75	82.64	291.54	15.00	80.78431702
8800.000	37.75	84.4443436	98.4313736	92	6625.00	82.64	291.54	15.00	80.78431702
8900.000	37.75	84.4443436	98.4313736	92	6625.00	85.13	297.48	15.00	80.78431702
9000.000	37.75	84.4443436	98.4313736	92	6625.00	85.13	297.48	19.00	80.78431702
9100.000	37.75	84.4443436	97.64706421	92	6625.00	85.13	297.48	19.00	80.78431702
9200.000	37.75	84.4443436	97.64706421	92	6768.75	85.13	297.48	19.00	80.78431702
9300.000	37.75	84.4443436	97.64706421	92	6768.75	85.13	297.48	19.00	80.78431702
Old Mar 31, 2015 | 04:53 AM
Vervish's Avatar
Vervish
Sweet! I gotta try this..
Here is my modded Spec B n E85 tune..i miss the tq.
Old Mar 31, 2015 | 05:29 AM
juanmedina's Avatar
juanmedina
Here is my WRX with a 6466 turbo on E85, I miss the thing. I need another turbo car, I will probably end up getting a supra or an EVO.
Yeah do an Airboy with your ISF I would love to see how much is putting down.
Old Mar 31, 2015 | 09:52 AM
juanmedina's Avatar
juanmedina
So it seems that the throttle position at 80% is normal:
https://www.clublexus.com/forums/is-...ing-100-a.html
Is there a way to log my car with my computer?
Old Mar 31, 2015 | 01:39 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Get a Techstream cable and run Techstream. It will log data.
Just to clarify - there will be no discussion of software piracy on this forum, especially for Denso proprietary software, but there are resources available to the public if you just look around.
Old Apr 4, 2015 | 05:04 PM
Justind27's Avatar
Justind27
Plx makes some good stuff, Ive been looking through their equipment and options (android or iOS is optional for display/logging)
rselby
IS F (2008-2014)
Aug 1, 2016 06:41 AM
jkeifer3
IS F (2008-2014)
71
Oct 13, 2015 03:07 AM
Perryz
IS F (2008-2014)
45
Jul 20, 2011 11:47 PM
CrazyMPG
IS F (2008-2014)
Mar 5, 2008 06:33 PM
houstonT
IS F (2008-2014)
14
Feb 21, 2008 10:17 AM
