Alternator Problem?
Old Sep 29, 2017 | 02:03 PM
Joker4096's Avatar
Joker4096
Is the new alternator charging correctly? I know remans are hit and miss.
Old Sep 29, 2017 | 02:13 PM
Rickna's Avatar
Rickna
I've had it for over 2 yrs. No problems so far...
Old Sep 29, 2017 | 04:09 PM
2013FSport's Avatar
2013FSport
I didn't spend a lot of time looking but a bunch lex and yodas use an overrun clutch on the alternator which can and does fail often.
If yours has a plastic cover at the pulley pop it off and verify the shaft is indeed spinning with the pulley while engine is running.
IS#50, GS, and a bunch of others have it and when it fails the alt output can vary substantially or be zero and many don't notice its a mechanical failure of the drive vs a fault inside the Alt itself.
Old Oct 1, 2017 | 06:14 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
The IS F also has a one way clutch on the drive.
Old Jun 18, 2019 | 04:55 AM
Evogixer's Avatar
Evogixer
10th Gear
Originally Posted by Rickna
So, on my 09 ISF w/20k mi I replaced the battery on 10/14. Now, about every 2 weeks the batt goes dead. I had it tested-it's ok. I also had the system load tested at Auto zone. It showed the alternator not fully charging. Hard to believe the alt has failed with such low mileage. Any ideas?
I'm in exactly the same situ, '12 F with 16k mls. Reading 13.4v irrespective of engine speed. Not too uncommon a problem it seems.
Old Jun 18, 2019 | 05:18 AM
Rickna's Avatar
Rickna
Interesting the we both had the alt fail with such low mi.
rx04Lexus
Apr 30, 2010 02:30 PM
lakemist
GX - 1st Gen (2003-2009)
Aug 5, 2009 11:11 PM
ArmyofOne
Maintenance
Nov 22, 2008 03:15 PM
RI-Lex
Aug 1, 2008 10:34 PM
