Rear deck lid
Old Nov 2, 2014 | 10:16 PM
ihiryu's Avatar
ihiryu
Default Rear deck lid
Hey guys, I'm looking to remove the deck lid on the F to check out the sub (seems like it's working sometimes).
I pull the seat bottoms up, and pulled the 12mm bolts to get the seat back off, I couldn't get the belts out, nor the through the deck lid. Any help would be appreciated!
Old Nov 2, 2014 | 10:32 PM
ISFPOWER's Avatar
ISFPOWER
1. pop the seat cushion by pulling the seat upwards. the cushion should pop off easily. push the seatbelt buckles through the slots. the cushion now can be removed completely.
2. At the bottom end of the seatback, there are 4 black 12mm bolts that secure the seatback. one of each near the door and two of them are near the center console. DO NOT remove the seatbelt anchor bolts which are 14 mm. lift the seatback to free it from the three upper clips.
3. remove the C pillar cover. start from the lower edge and just using fingers to carefully pry them off. each piece should be held down by three blue plastic clips.
4. pop off the rear deck by lifting the front edge carefully. it's held down by three clips.
5. you now have access to the subwoofer or the brake light. the subwoofer is secured by four 10 mm bolts.
Old Nov 3, 2014 | 09:55 AM
ihiryu's Avatar
ihiryu
Thank you sir! I was able to reach and disconnect the subwoofer without removing the deck lid. It isn't working
Old Nov 3, 2014 | 10:28 AM
Justind27's Avatar
Justind27
Awesome I was curious where that thing was
MicaISF
IS F (2008-2014)
14
Apr 3, 2015 09:34 PM
tbilisi79
Nov 20, 2013 02:42 AM
mad_trbo
GS - 1st Gen (1993-1997)
Nov 26, 2008 04:56 AM
blueleex
Aug 9, 2008 09:34 PM
lexodude
Jun 19, 2006 01:38 AM
