Reassign Steering Wheel "Mode" Button
Old Feb 21, 2015 | 08:15 AM
Quadrphnia's Avatar
Quadrphnia
Golfer2000 - thanks a million for the diagrams.
I'm all over this come Spring. I put the word out to my fellow elec buddies for assistance / supervision.
Old Feb 22, 2015 | 04:37 PM
Golfer2000's Avatar
Golfer2000
Not a problem hopefully someone can figure it out sooner than later. The car has only been out for 7 years lol
Old Feb 22, 2015 | 07:51 PM
Fsport2UR's Avatar
Fsport2UR
Originally Posted by Golfer2000
I'd assume the way to do it would be to take the J24-5 (AU2) wire, cut it so that it isn't changing the inputs and then tap it into the J36-6 wire. Again this may be all wrong but that's what I came up. Let me know what you guys think.
That will work, BUT the VOICE and HOOK On/Off Switch buttons are tapped in to AU2 also. Meaning you will lose the VOICE and Hook On/Off buttons.
But what do I know, I only have a degree in the electronics field.
Attached Thumbnails Reassign Steering Wheel "Mode" Button-au2_mode_voice_hook_switch.jpg
Old Feb 23, 2015 | 06:06 PM
Golfer2000's Avatar
Golfer2000
Well that makes you light years more qualified than me. tell us how to do it
Old Feb 24, 2015 | 09:53 AM
rmillsISF's Avatar
rmillsISF
Biggest problem I see is you have 1 wire functioning for multiple switches. If you splice this in you're going to lose functionality to other switches. I don't see an easy wiring work-around. I could be wrong
Old Feb 24, 2015 | 11:10 AM
Fsport2UR's Avatar
Fsport2UR
I already explained how I would do it on the previous page.
Not correct. Yes in that one wire(AU2) runs up to the steering wheel controller switches, BUT from there splits in to the 4 switches(MODE, Hook On, Hook Off, and Voice). How I would do this is access the MODE switch itself, and cut that wire leading to it(the other 3 switches would still work). This is going by the documents posted, I would still have to crack the units open to actually see and be positive. And to be honest, I really don't care to have MODE switch set to Sport mode, so I doubt I will even take my steering wheel and dash apart. But if anyone else manages to experiment on their car and post photos, I'm willing to help or give advice.
Old Dec 7, 2018 | 09:04 AM
viprez586's Avatar
viprez586
thread bump,
So this is all great on paper, and looks like it will work.
Has anyone successfully done so?
Old Dec 11, 2018 | 08:16 PM
Joker4096's Avatar
Joker4096
I'm tempted to try to tackle this when I have time.
Old Dec 11, 2018 | 08:23 PM
viprez586's Avatar
viprez586
I'm looking into remote start options since I got the major hookup on wiring locations from an installer.(saves me so much time researching every friggin wire)
while I'm doing that I'll look into modifying Pins as well.
Old Dec 14, 2018 | 05:33 AM
Rickna's Avatar
Rickna
Originally Posted by Kyle4207
I've successfully done the button swap and it's pretty easy after studying the wiring diagrams. I just haven't had time to do the write up. I've put in the 2013 steering wheel buttons into my 2010, using the factory wire harness I tapped into the factory wire harness after the spiral wiire connector in the steering column. Essentially you use the circuit that is there for the radar cruise control. If you have that option you shouldn't rewire it.
I tapped into the harness where the radar cruise control ECU would have been plugged into, then ran a wire over to the Sport button and tapped in there. This maintains the functionality of the stock button as well.
I don't have much time but will try to write something up in the next couple of months and post it.
Based on your solution I will be doing the same. I have ordered 2013 buttons from megazip (less than $200). Thank you for the inspiration!
Old Jul 18, 2019 | 10:27 AM
Richy21's Avatar
Richy21
Next mod! everything else works tho?
Old Jul 18, 2019 | 01:56 PM
Rickna's Avatar
Rickna
If you're interested-
DIY
jleonard71
IS F (2008-2014)
30
Sep 15, 2016 04:46 PM
StraySheep
IS F (2008-2014)
Feb 23, 2014 05:55 PM
Yummy66
RX - 3rd Gen (2010-2015)
Feb 22, 2014 05:42 AM
BJM711
IS F (2008-2014)
25
Sep 21, 2010 04:36 PM
Atl
Mar 3, 2008 06:12 PM
