Isf air intake system
Old May 25, 2014 | 01:10 PM
MYISF's Avatar
MYISF
Not yet but will very soon...problem is I have no idea whether the intake and filter would really help WHP at all as I installed all three I/H/E at once and did not dyno before hand...my hope is around 400whp...that would make the I/H/E install worth it to me
Old May 25, 2014 | 08:42 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
I wouldn't care if the dyno said an intake makes 100 horsepower. Run the car down the track, look at the trap speed, and decide for yourself if it worked or not. Dyno numbers are for impressing those who fail to understand real world performance. Just because you dyno a big number does not mean the car is actually faster unless you test it and validate the dyno's result with trap speed or acceleration times.
Old May 25, 2014 | 08:57 PM
2bais's Avatar
2bais
Group M???
Old May 26, 2014 | 04:41 AM
ISF2012's Avatar
ISF2012
Originally Posted by yishin
I had the stock intake with afe dry filter drop in
and then upgrade the pipe to joe z intake tube set up
right now I have a injen open box intake with vented hood
i like the open box intake on this one so my votes are either injen or takeda
Sounds good , ok can i change the intake with joe z pipe for lSF (2006-2010),cuz my ride 2012??
Old Nov 6, 2023 | 09:56 PM
2012MMISF's Avatar
2012MMISF
1st Gear
Do you guys believe a Takeda cold air intake will be beneficial compared to just getting an hps intake elbow?
Old Nov 7, 2023 | 06:15 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Beneficial in what way? Intakes haven't shown real success in adding power.
https://www.clublexus.com/forums/is-...takeda-14.html
Old Nov 8, 2023 | 04:27 AM
KennyFSU's Avatar
KennyFSU
It will be louder, and louder = faster.
Old Nov 10, 2023 | 10:41 AM
ubersonic's Avatar
ubersonic
No, it uses an aFe cone filter that has less surface area than the factory filter.
You can buy aftermarket panel filters made by aFe (among others) that will perform better.
Old Nov 11, 2023 | 04:07 PM
silverevo's Avatar
silverevo
AFE drop in..stock intake..search on intake..it's been proven it's the best. After a tune an after market changes that. Depends on the avenue you want.
FIGS
IS F (2008-2014)
208
Oct 18, 2024 02:54 AM
rselby
IS F (2008-2014)
16
Feb 27, 2021 07:33 AM
yishin
IS F (2008-2014)
Apr 13, 2014 08:42 PM
KOKISF
IS F (2008-2014)
17
Jan 1, 2013 10:45 AM
