Joe Z exhaust issues
Old Apr 29, 2014 | 06:26 AM
dave4262's Avatar
dave4262
Default Joe Z exhaust issues
HELP ...Just got my JOE Z exhaust installed and now a rattle in the front when going over bumps.
Old Apr 29, 2014 | 06:32 AM
melbitoast's Avatar
melbitoast
There should be a plethora of guys to help you here. My guess would be an installment issue (perhaps a loose bolt or something similar) b/c I've never heard of anyone having issues with their Joe-Z exhaust. Good luck, and I hope it gets corrected quickly.
Old Apr 29, 2014 | 06:47 AM
TranV's Avatar
TranV
^^^ what he said. just got mine installed about 3 weeks ago and no rattle here.
Old Apr 29, 2014 | 07:25 AM
MYISF's Avatar
MYISF
I have had mine almost two months now with no rattles...I had the Sikky headers and Joe Z installed at the same time...I had major conversations with Lexus of Tampa Bay about rattles and actually stopped by there 1/2 way through the install (headers where done and exhaust was next)...the only thing that we saw when holding the exhaust in place prior to install that may have caused a rattle was a cover for the driveshaft...a small corner of it extends out over the exhaust...they removed it and cut the corner off so there would be no chance of a rattle...other than that we saw no other places where it may rattle as it is a quality system!!! Good luck.
Old Apr 29, 2014 | 07:41 AM
Weapon F's Avatar
Weapon F
Three years now no issue at all great product.
Old Apr 29, 2014 | 07:54 AM
Evil Teo's Avatar
Evil Teo
is it when you are also making a turn or just over bumps? also is this a used exhaust or new? could be what others have suggested something might be loose from installment or the exhaust might be hitting against the plastic trim underneath. that happened to me and I just trim the plastic down. Joe will probably chime in soon.
Old Apr 29, 2014 | 08:18 AM
dave4262's Avatar
dave4262
I appreciate the feedback from you all.
This only happens over bumps. The exhaust is new and all hangers are installed.
Teo - which shop install your exhaust?
Old Apr 29, 2014 | 09:00 AM
yishin's Avatar
yishin
Joe z exhaust was by far hight gt pipe u can get in my book
Lift ur car and look under the car n check the angles of entire exhuast pipe if it rattle like some metal rattling then possible with the when u go over the bump the pipe is hitting some metal sheey under the car if the bolt was missing or thing like that thats exhaust leak tell the installers to do it again i pretty sure its not a joe z exhaust product fault
Old Apr 29, 2014 | 09:14 AM
Evil Teo's Avatar
Evil Teo
I actually went around my block to get it done. only needed a lift and helping hand.
Old Apr 29, 2014 | 10:23 AM
digger08's Avatar
digger08
Check for clearance on the cross member, just behind the transmission. This is usually where some knocking can be heard.
While not a JOE Z exhaust (ISS forged) there is 2 cross members that can be bumping the pipes and I also believe there is another one near the back..
Of course none of these noises would emanate from the front of the vehicle.
Perhaps the rattle is rust bits or debris from the installer, stuck in the pipes......does it make the noise while idling?
Digger08
Old Apr 29, 2014 | 10:31 AM
Joe Z's Avatar
Joe Z
Exclamation
Get it on a lift and check clearances.. Adjustments can be made easily..
We can't be under the car for every install...
I'm trouble shooting another install that just happened, where the installer left out the forward OEM gaskets.. Causing CEL's
So even though we do make these system as a simple bolt on.. The installer is the most important part of the process.
~ Joe Z
Old Apr 29, 2014 | 10:46 AM
Joe Z's Avatar
Joe Z
Question
Also, are you still running aftermarket headers??
Your threads:
2011 Lexus ISF rubbing sound when turning left
Sikky headers - "Left Turn Rattle" club
As a side note, if you had issues before our exhaust install, they will be there after as well.....
Thanks
~ Joe Z
Old Apr 29, 2014 | 11:22 AM
dave4262's Avatar
dave4262
I have silky headers and i did have issues but it was resolved awhile ago.
Old Apr 29, 2014 | 12:05 PM
Joe Z's Avatar
Joe Z
Lightbulb
Headers are shifting the exhaust alignment... Check the pipes clearance everywhere on a level lift
Let us know how that goes...
~ Joe Z
Old Apr 29, 2014 | 01:19 PM
Evil Teo's Avatar
Evil Teo
Dave where did u get the headers installed?
