Rear Sway Spec.
Old Apr 16, 2014 | 10:43 AM
bacardi11's Avatar
bacardi11
Default Rear Sway Spec.
hi guts
dose any one know the spec. on the ISF rear sway rear meaning length of bar, hole to hole length ect,ect. thanks
Old Apr 16, 2014 | 02:07 PM
flowrider's Avatar
flowrider
Veteran: Air Force
Look at Post #25 Here:
https://www.clublexus.com/forums/is-...way-bar-2.html
Lou
Old Apr 16, 2014 | 02:29 PM
I8ABMR's Avatar
I8ABMR
I measured it for a member who was wondering if it would fit his SC430.
Thanks for directing him Lou.
Old Apr 17, 2014 | 12:58 PM
bacardi11's Avatar
bacardi11
getting the IS-F rear sway bar from Sleepy 32" long 17mm the 430sc stock rear sway bar is 32" long and 12"mm
this will be a great upgrade for my car. a friend of mine just installed a gs430 19mm on his car with a little cut work.. he is the only one with anything bigger then 12mm on the 430sc.
Old Apr 18, 2014 | 12:00 AM
lobuxracer's Avatar
lobuxracer
Tech Resource
Stiffer sways are typically NOT an upgrade, they just reduce the independence of an independent suspension. You'd be way ahead to put stiffer springs on the car first, especially if you're concerned about roll.
Old Apr 18, 2014 | 02:58 AM
bacardi11's Avatar
bacardi11
lobuxracer
I use Swift Springs with my 430sc now great springs. I will have the ISF setup on my car. 17mm IS-F rear bar and the gs430 28.6 front.
guys in Japan use the 17mm rear and 28.6 front they say it works nice for the street for the 430sc. parts from Japan very costly shipping cost. 19mm to stiff for the street.
I under stand you can get the upgrade setup from the factory now.
bacardi11
Jan 10, 2024 11:21 AM
ISFCOBRA
IS F (2008-2014)
36
Nov 25, 2020 08:37 PM
LexBrett
Jan 9, 2015 04:20 PM
bacardi11
IS F (2008-2014)
Apr 23, 2014 07:40 PM
