Wheel fitment question
Mar 18, 2014 | 02:07 PM
Looking at some 20x9.5 30mm front and 20x10.5 35mm rear wheels. Will they fit or have clearance issues with the brembo brakes?
Mar 18, 2014 | 02:35 PM
Will fit.
Clearance with brembo brakes has more to do with the back spacing than the offset.
Mar 18, 2014 | 05:10 PM
thats going to be dependent on what disk face are the wheels going to be more so than the offset
Mar 18, 2014 | 07:19 PM
Quote:
Originally Posted by
ISFpat
Will fit.
I have always associated offset with backspacing. The attached is from Tire Rack.
Lou
Mar 19, 2014 | 09:30 AM
Turizmo01
On stock suspension I assume?
From what I have gathered the front will rub (245/30/20 tires) but they may be able to make it work as I was told a 20x9 +35 would rub a little.
The 20x10.5 +35 should rub but depending on which tire (285/25/30) and your fender may need to be rolled.
Just my 2 cents
Mar 19, 2014 | 10:37 AM
Turizmo01
You are fine in the front. But the rear will be difficult. I have 19x10 +35 rear and I had to roll the fender.
2010ISFU
IS F (2008-2014)
Mar 19, 2015 11:17 AM
Tdvlexo
Feb 13, 2010 08:20 AM
SorrGwa
Mar 24, 2008 07:22 PM
Gs430Boi
Mar 11, 2008 08:52 PM
fleadog99
Sep 8, 2006 12:36 AM
