Look Here 2011+ LED headlights Stand Alone Fog DYI
Old 03-31-14, 07:48 PM
  #31
Rickna
Rickna's Avatar
Great write-up & thread. A lot of info here. I will be doing this soon. Thanks to OP & all contributors.
Old 04-01-14, 09:26 AM
  #32
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
So, I'm thinking about giving this a try.. Although a part of me just wants to run a Stand Alone harness..
They make them pretty inexpensive these days..
ULTSISF - What color does the Toyo switch light up ? Amber or Green ??
Also, when running the wire to the CIG Lighter or other source.. with the spearate switch set to OFF or not engaged, does the oem Stalk switch still operate on/off ??
Thanks
Joe Z
Old 04-01-14, 09:47 AM
  #33
ULTSISF
ULTSISF's Avatar
JoeZ I opted to not run n extra wire for the light but when I first test it the color was orange. Also if u remove the (rubber thingy covering the bulb I will say the light will be white).
Old 04-01-14, 11:13 AM
  #34
Joe Z
Joe Z's Avatar
Awesome thanks...
Did you happen to take a picture of the back side of the button ?
~ Joe Z
Old 04-01-14, 11:15 AM
  #35
ULTSISF
ULTSISF's Avatar
Originally Posted by Joe Z
Awesome thanks...
~ Joe Z
Sorry nope....
Old 06-17-14, 03:31 AM
  #36
specie
specie's Avatar
Anyone got the fog lights to turn off when the car is off? Is Ricky350IS' the only method for this to work? Any potential problems in using the lighter as the power source?
Old 06-17-14, 03:34 AM
  #37
ULTSISF
ULTSISF's Avatar
My method works with the car being off.
Old 10-18-14, 01:04 PM
  #38
TomTom236
TomTom236's Avatar
Which wire is the power, the solid white or green with red stripe?
I would like to do this, but want to tie into the cig lighter for power.
Thanks!
Old 11-10-14, 11:17 PM
  #39
TomTom236
TomTom236's Avatar
I just wanted to say thank you to ULTSISF for answering my PM's about this. I have a 2011 F Sport and have been searching for a way to do this for a while! Found this thread a few weeks ago and Decided to do it earlier tonight. Here's the outcome:
For anyone curious, the white wire is the power and the grren/red is the accessory/fog light wire.
I used this rocker switch and mounted it in the empty middle slot next to the coin holder. http://www.otrattw.net/CONTURA-V-FOG...PZC4S-57U.html
Old 11-12-14, 04:50 PM
  #40
rselby
rselby's Avatar
will the same wires work for an 08 that don't have the LED's in the headlights
Old 12-29-15, 06:33 AM
  #41
Vitveet
Vitveet's Avatar
This is the thread I've been looking for! For for all contributors and info! Ordered my switch and will be doing this mod this weekend hopefully!
I will suggest that if you follow the OPs method thayou put an inline fuse in-between the white wire and your switch. 10a should work fine. Just in case of a short, replacing a $1 fuse is much less headache than replacing a $30,000 to $60,000 car!
V.
kauaian
13
01-15-14 06:55 AM
PumaFiveOh
08-26-13 09:12 PM
Vroomin350
21
02-06-12 06:44 AM
lx470man
IS F (2008-2014)
18
02-17-11 08:56 AM
Quick Reply: Look Here 2011+ LED headlights Stand Alone Fog DYI
