My first dyno
Old Jul 27, 2013 | 12:12 PM
Polkman's Avatar
Polkman
Default My first dyno
Well I finally got a chance to dyno my isf, was hoping for a higher number but oh well.
This run was with a borla catback,joez intake,toms drop in
All runs were done in 6th gear, except for the last which was done in 5th.
[IMG][/IMG]
Old Jul 27, 2013 | 12:20 PM
BS ISF's Avatar
BS ISF
Don't worry about the dyno just hit the track. Numbers look a tad low but every dyno is different and looks like it was hot and humid.
Old Jul 27, 2013 | 01:16 PM
flowrider's Avatar
flowrider
Veteran: Air Force
Actually his numbers are not out of line with what has been posted before. Dyno runs should be run in 6th as that is the one to one ratio gear.
Lou
Old Jul 27, 2013 | 01:37 PM
RX7 RAGE's Avatar
RX7 RAGE
Seems a bit low and those runs weren't even in SAE 5 format...
Old Jul 27, 2013 | 02:21 PM
Polkman's Avatar
Polkman
Yeah I'm just hoping it was due to the humidity. Ill take another shot at it when the humidity goes down.
Old Jul 27, 2013 | 03:01 PM
Murph145's Avatar
Murph145
All dynos are different dont use a Dyno as a end all of end all measurements. A dyno is good for doing a base line measurement and when you do a mod such as exhaust or headers you can go back and measure the gains in performance off your base run. Dyno pulls are really pointless in my opinion only useful in measuring gains in mods
Old Jul 27, 2013 | 03:41 PM
Polkman's Avatar
Polkman
Was planning on going with headers soon, therefore I wanted to see the gains. However was hoping my numbers would've been higher. I am planning on going to the drag strip soon for the first time ever as well, hopefully I can break into the high 12s.
Old Jul 27, 2013 | 04:40 PM
Murph145's Avatar
Murph145
Your numbers are fine if engine hp is 406 u lose approximately 15% from the drive train so 350 is about normal
Old Jul 27, 2013 | 05:23 PM
chrisp1's Avatar
chrisp1
post the numbers when you go to the strip!
Old Jul 28, 2013 | 05:00 AM
CUTigers's Avatar
CUTigers
CL Folding 100,000
more than 406 :-p
Old Jul 28, 2013 | 11:05 AM
Murph145's Avatar
Murph145
416 lol whatever I'm lucky I can remember my street address
Old Jul 28, 2013 | 12:49 PM
ferraribuy's Avatar
ferraribuy
do the headers add much Hp? I need exhaust that sounds better whats the cheapest fix for that?
Old Jul 28, 2013 | 01:56 PM
RCM83's Avatar
RCM83
Headers are 40+ to the wheels
Old Jul 28, 2013 | 02:38 PM
flowrider's Avatar
flowrider
Veteran: Air Force
If you look at my graphic (Post #3 above) you'll see it's about 30 to 35 BHP.
I'm attaching a real old Dyno I did, just after my header install. You'll see about a 30 BHP increase with PPE headers vs stock manifolds.
Lou
Old Jul 28, 2013 | 05:43 PM
CUTigers's Avatar
CUTigers
CL Folding 100,000
BHP is crank/motor HP i thought?
